Question about Stoves Premier 720EMa Electric Double Oven
Dual grill does not work
I ahve replaced the element and the energy controller and the grill still does not function - the indicator light does not work either
any ideas?
  • 417 Answers
It sounds like you have no power to the the grill. Check the grill circuit with a tester until you identify where you have power to and then check for loose connections or broken wires from there on.
Posted on Nov 29, 2008
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
The main oven doesn't heat but the main oven grill function does heat up! I'm not sure if this means the element is no longer working or if it is a problem with the control switch?
Make sure the power is off, then there should be two screws holding the element to the back wall remove them. Pull the element out until you can get to the wires, sometimes a wire will burn off at the connector, if that's the case replace it with a high temp connector if not disconnect both wires and do a continuity check on the element
Apr 14, 2015 | Ovens
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 | Smeg Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves Premier 720EMa Electric Double Oven Logo
234 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
