Question about GE Spacemaker JVM1640SJ Microwave Oven
I started my microwave and there was a corn kernal stuck underneath my rotating glass plate and it caught on fire and burned a small dentation in the bottom of the microwave. Can I safely run it? Can I recoat over it with something?
  • GE Master
  • 9,098 Answers
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
It's safe to run in the very short term, but if you run it too long without fixing the blemish, it may arc and char more.
Posted on Dec 02, 2008
A small fire started inside the oven. Only the glass broke everything else seems fine. Can I continue using it.
Maybe, maybe not.
You can probably find a replacement glass tray at a Good Will store.
I don't think I'd run it indoors any more. I'd set it on a couple of cinder blocks in the middle of my concrete driveway and hook it to a long, heavy duty extension cord.
Wear a face shield and stand back at least 10 feet after pressing the start button.
You should go to YouTube and search "Can you microwave that".
It's a series of videos.
Feb 26, 2015 | In Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave turntable stopped and is now burning food
The turntable is driven by a small electric motor mounted underneath the cabinet. The motor may have failed. Also check whether the rotating plate was binding which also causes failure of the motor
Dec 23, 2012 | Whirlpool GT4175SPS Stainless Steel 1200...
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
I have an Emerson Microwave 700W W7300W. I was popping a bag of corn and the plate inside broke completely in half.
measure the glass plate diameter , you can buy them on Ebay , but since they make these fast and cheap, the glass plate might of had a flaw in side like Toyota ......................
Mar 14, 2010 | Emerson Microwave Ovens
Glass plate does not rotate
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
