Question about Sony UY-S100 Film Scanner
My Scanner Died in the middle of scanning
I was scanning a slideshow onto my computer when all of a sudden, during one of the scans, my scanner shut down and stopped working. Prior to the scanner shutting down, I heard a pop coming from the rear of the machine. Now my scanner will not even turn on. If anyone knows what occurred and how I can go about fixing it, please let me know.
    Scholar:
  • 59 Answers
Coudl have been a fuse, a bulb, but most likely you would know if it was the bulb, and it was probably a capacitor overloading and exploding, its repairable if you can locate, de-solder, and replace the blown capacitor, your best bet is probably going to be to purchase a new scanner, unless it was just a short in the power cord in wich case the power cord may be the only thing effected but that almost never happens, I'd put my money on a blow cap but then again i could be wrong
Posted on Apr 23, 2007
Pop? Maybe the fuse blew...
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
I have scanner hooked up to laptop and i press scan, it says scanning but has nothing showing up for a picture scanned
Is this a new scanner? If so, most scanners come "locked".
Make sure you consult your user manual and remove the lock (usually by turning a knob/handle/switch under the hood somewhere).
If this has scanned before, watch the scanner bed as you try to scan. If the light does not coarse the entire scanner bed, then the lock may have become re-enabled... or the motor could have come off track. Sometimes this can be fixed by manually adjusting things inside (be careful! as this could really damage your scanner).
If the light does move entirely across the bed, try to re-install the software onto your computer. If you dont have the software, you can grab a copy at dell's support site.
Also, check your cables. If you are trying to scan through a network, you might try USB instead, just to make sure the scanner works. and its not a connection problem.
The connection type can be set during installation.
Hope this helps!
Feb 23, 2011 | Dell P703w Printer
I want to save the scan to the computer. What do I have to do?
HI, If you have Photo shop Elements, go to File then Import and look up you scanner from the list. If you are scanning from the scanner, it must see your computer to save to a file you created.
I use Photo shop, I've never scanned from the scanner onto the computer.
Take care...
Nov 15, 2010 | Lexmark X5150 All-In-One InkJet Printer
When I am scanning negatives, and try to save my scan to a file on my computer, it sounds like something is stuck and when the picture is finally saved, the middle of it is blank or shows rainbow-like wavy...
There is usually a locking lever on the bottom of the scanner to lock the mechanism during shipping or transport. Make sure that lever is fully in the unlocked position!
Oct 22, 2010 | HP ScanJet 3970 Flatbed Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Florescent light died on my scanner, glows a
The bulb is blown, it may function once in a while, but repairing may be too costly.
Your scanner has a 1200dpi resolution. There are similar, yet better scanenrs for less than $50.
You might consider an EPSON scanner/printer for under $50. Some EPSSON printers can also print CD labels, directly printing onto the CD!
Sep 28, 2009 | Plustek OpticBook 3600 Plus Flatbed...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Plustek wont scan
no the problem is check the path u mentioned in the scanner preferences and settings i mean the folder mentioned to store the scanned images after the scan , scanner is given a path to store these images by default check and change that path to other location on hard drive and everything will be ok if the problem persists then update ur driver from plustek website
Feb 24, 2009 | Alestron OpticSlim M12 Path-Through...
Umax Astra 1200S Scanner Problem
Open ur scanner ,s back body(its very easy)remove belt.. just clean scanner, s belt and dust from scanner with soft cloth..put it belt again..
Mir
Jul 05, 2008 | Umax Astra 1200S Flatbed Scanner
Scanner - Scanning Bar Became Stuck
if the scanner bar is stuck in the center then U hav to call Lexmark tech support at 8003324120 & have them chk the warranty of the printer.. if its in warranty it can be replaced
May 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Sony UY-S100 Film Scanner Logo
105 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
