Well GE manual is certainly careful not to show how to install this thing.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=982440113.PDFGE parts phone number: 800.626.2002
Blue line connects to bottom of Faucet that comes with unit. I assume the faucet fits in pre-drilled hole in your sink, for example where the spray hose used to connect.
Yellow line connects to top of tank that comes with unit.
Green line connects to cold water line. You might have to make some changes to your cold water shut-off valve to connect green line. If product does not come with a fitting that connects to shut off, then I would probably buy a shut-off that has two connections.
Red line is a mystery. It looks like a discharge line, and the manual is blank on the installation. If the faucet does not have a second fitting, then the red line is probably suppose to rise up to the height of the faucet before dropping down into the drain. This amazingly sanitary plan does not show specifically how to tap onto the drain line, so I suppose you drill a hole and wrap it with some sort of sealant, and then duct tape the red line to side of drain pipe to make sure it doesn't fall out. But I'm not sure what installation method is best for this. It will be a challenge getting your electric drill into the cabinet to drill into chrome tubular drain pipe without bending the tubular wall. Hopefully you have a plastic drain line and perfectly sized drill bit. I can't imagine you're supposed to install a plastic cup under the sink to catch the drain flow.
Manual says you need screwdriver, pliers and a drill. The tool list seems a bit short.
Add a comment here and let others know the details of your installation because you know others have same questions, and they will see this post.
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on smartwater or any do-it-yourself project.
Fixya is always less expensive than a service call.
