Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
It fills, but nothing happens. I've been lifting the lid and letting it bang back down and it starts and completes the cycle...but after a few months of that, now it doesn't work at all.
Timer? Lid switch? I want to fix it but am not sure where to start, thanks!
  • 2 more comments
  • juliejfitch Nov 30, 2008
    I have exactly the same problem...Where do I start?
  • tph43 Dec 01, 2008
    Same issue for me. It used to be that I could bang the lid down and it would work. It doesn't work anymore. I think it may be the lid switch assembly but I'm not sure. Any help would be great!
  • Anonymous Dec 09, 2008
    My Maytag is filling up, then stops. Slamming the lid a few times will usually start it. Iv'e checked the Lid Switch and replaced it but the problem still continues.
  • tx24fan Dec 14, 2008
    the washer fills but, dose nothing else
  • 868 Answers
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Posted on Dec 02, 2008
Maytag Atlantis MAV6451 - The machine buzzed and stopped. Now it wont run. Dont think its the lid switch
does it fill with water?
Does it not do anything after it fills?
If this is the case than it is most definitely the lid switch.
I recently had the exact same problem. Easy fix if you are handy.
Remove back of control panel to access the mounting screws. this will give you hand access to the lid switch. Try manually activating it after letting it fill. Replace switch or repair if able.
Good luck
Sep 30, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My Maytag model # LAT8504AAE WILL NOT do anything
check your lid switch you should hear it click when you open and close the lid. take off the screws to the back of the console 3 philips and 2 1/4in screws, I think, anyway when you get it open the lid switch is the white box that is kinda set into the frame . remove it and push it manually. let me know what you find good luck.
Jan 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, and thats it.. will not do anything else
There is a problem with the lid. Push ******* the front of the lid. It should work. Mine has been doing this for 6 years.
Dec 03, 2008 | Maytag MAV6200 Top Load Washer
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer
the timer might be broke, well let me explain more the prongs on the back of the timer might not be making contact so the washer will not start.
Feb 12, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't work... Period
the lid switch on the washer went bad. with out the lid switch working the washer cant do anything. its there as a safety to stop the washer when the lid is raise but when it goes bad it doesnt know if the lid is down or not so the washer wont come on
Nov 25, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
214 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
