Question about Video Game Consoles & Games
There is something wronge with my xbox360 when i put it on the digital t.v an error come up it is called error e79. my xbox has 3 rings lighting up is there is there something i can do to get it working again or is there somewhere i can take it to fix it.
Wrap a towel round it for a temporary fix.
http://uk.youtube.com/watch?v=838Nqly9z3c
otherwise you can use the X-Clamp fix.
http://uk.youtube.com/watch?v=5axYHeG4Xeo
But first try sending it back to Microsoft.
Posted on Nov 29, 2008
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
I have an xbox360 I had almost a year I went to switch it onan a red light apear and tells me to go to xbox custemer care E37
Jan 21, 2011 | Microsoft Xbox Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
I am having a problem with my xbox360. a single red light problem and also in game,picture gets blurred and pixels gets stretched....help
Jan 08, 2011 | Microsoft Xbox 360 Console
I started my xbox360 and my controller won't connect and then a red light came on in the right bottom of the circle .what do i do ? Or what is going on?
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
My xbox got one ring with error code E79 or E71
Well, E79 and E71 are different things.
The E79 is an error code representing a Hard Drive error. It could be the HDD itself or its a connection problem with the hard drive. Try playing your 360 without it and see what happens.
E71: possibly a dashboard update error, there is no solution at present the console must be sent back to MS for repair. Try resetting your console, or Power Off, remove the HDD if you have it. Reconnect the HDD.
Jul 15, 2009 | Microsoft Xbox 360 Console
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 3-red lights may be caused by DVD drive? Help please!
your 360 is a first run off assembly. they were junk from the start. my warranty expired also but called microsoft and they said if the ring of death is related to the first run of 360s they willextend the warranty. exactly what happened to me. 8 days later they sent me a brand new 360 cause problems with the first run 360s can't be properly fixed. contact them tell them the problem and you will get a new one. hope this helps Tadster
Apr 15, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
59 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
