Question about RCA P61929 TV
No Picture It was working fine. I went to the restroom, and when I came back, there was no picture. I hate to throw it away, if there's a simple fix.
  • 1 more comment
  • dfw24 Nov 29, 2008
    I unplugged the unit(for days), and still has no picture or sound
    The only fuse I could find, is good, so it sounds like an expensive problem. I guess I'll have it hauled off. Thank you for your time.
  • dfw24 Dec 04, 2008
    I was watching a movie through a DVD player. I paused the movie, went to the restroom, and when I returned, I thought someone had turned the TV off. There is no picture or sound. When I turn it on, I hear a dull click, and 2 or 3 seconds of static electricity that fades out, and then no sound at all. The only fuse I can find is at the power supply, and tests good.Thanks for your time.
  • 4,234 Answers
Something inside the set has failed and is causing the set to fall back into "protect" mode. The click you hear is the power relay. The high voltage section is turning on for a few seconds then shutting down. Without seeing the set and taking measurements inside, there is little anyone can do remotely. It is possible that an Eprom reprogramming can fix this, but that would involve the use of another Eprom on a temporary basis and can only be done at a service shop.
If there are other symptoms that you have not listed, they may give us more clues to determine the exact problem, but as it stands you should bring the set to a servicer for an estimate. Armed with the estimate we may be able to guide you through the actual repair.
Keep us posted,
Dan
Posted on Dec 04, 2008
    Guru:
  • 558 Answers
How old is your TV? Is there any Voltage fluctuation occurs or electric breakdown?
Take it to nearby repair shop or if you have enough tool to perform a test yourself then go to check its Power Control board inside the cabinet with a Multimeter for all link and circuits. May be an IC or resistor broken down.
  • RCA Master
  • 19,396 Answers
If the TV led is on, and TV does not start but you can see that there is power getting to the TV, then you need to call a technician.
If instead the TV does not start at all and there is no power at all getting to the unit:
If you leave in UK check the fuse inside the AC plug, you do not need to take apart the TV to do this.
If the Cord/Plug is not fused, there is a fuse inside the TV , on the power board, but to replace this you also need to take apart the TV, and therefore is advisable to call a technician.
A suggestion:
If this is a CRT TV, the traditional TVs with CRT tube inside, get it replaced with an LCD or Plasma TV.
This are more expensive, but waste far less energy, and can pay themselves on your bills over few years.
Do not buy a new CRT, nowadays has become an obsolete technology.
Posted on Nov 29, 2008
    Scholar:
  • 126 Answers
If you turned the TV off and then turned it back on and the picture is still not there try making sure all cables in the back are plugged in securely. Check the cable box to ensure the cable box did not fail. With the limited info you give I am limited with the solution. Do you still have audio with no picture? Does the power come on? Please post back
  • Slick54 Dec 04, 2008
    I have to agree with abvrcsm it's the main board, the click and the static electricity are 2 guaranteed signs it's the main board. If it is a CRT it will most likely cost you as much as a new 26in LCD. I recommend 1. take it to a tech and get an esimate, if it's out of your budget they will galdly keep it so you won't have to pick it up.. as they get there parts at wholesale so for them to fix it and resell it is not a problem, however, no guarantee they will do that, however they do know the proper disposal precedure. Hope this helps.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, any other indications like flashing LEDs at the front control panel? If yes, any sequence and how many blinks? Any clicking/chirping sound from the back? And are you considering a DIY (do-it-yourself) repair?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 276 Answers
Its the problem in the main board of your tv .may be caused due to extra current passed from the unit at that particular time and because of that the fuse of the tv is blown off.this could be the common cause for this problems.but it could also be the faulty capacitor on the main board and that capaCITOR needs to be replaced to clear this problem.
    Sergeant:
  • 291 Answers
Just unplug the unit from main power outlet for sometime then replug it and check out .this mostly gets resetted.
  • jamesrated Nov 29, 2008
    if still the problem then its the error in the main board and needs a reparing.
NO PICTURE NO AUDIO VIZIO XVT553SV MODEL.MANUEL START ONLY HAVE WHITE SCREEN NO PICTURE,,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 03, 2017 | Vizio Televison & Video
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Kenmore Elite Microwave has power but will not start?
switch if off completelty for approx 5 mins and then power it back on
Oct 26, 2011 | Microwave Ovens
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
NO PICTURE ON MY FLAT SCREEN TV, JUST SOUND
TV has sound but no picture. Earlier it started flasing differnt colors then went black. Whats up can it be fixed or do I need to throw it away?
Oct 24, 2009 | Dell W4201C 42 in. Plasma HDTV
My analog tv does not hold on to the picture. So
you probably need a digital converter box, analog signals were banned like in febuary.
Sep 15, 2009 | Televison & Video
JVC AV-27720 TV Problem: Picture goes to horizonal white line in center.
In most cases the following parts need to be replaced I think the part location numbers are accurate
IC421 LA7832 ( vertical output IC )
Capacitor C424 100UF @35v
Zener Diode D422 MTZJ75-T2
Resistor R541 1.8ohm 2watts
Oct 23, 2008 | JVC AV-27720 27" TV
Corel Gallery 1994
How I fixed it, I threw it away. Your gal at the 1-800 told me there was no way I could ever get it to work, there were no patches or help available. Shame, there were lovely and clear clipart.
Shame you do not care about your programs from the past.
Rex
Feb 06, 2008 | Corel Gallery FunArt (CGFA10ENG0) for PC
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
