Question about Frigidaire Affinity ATF7000E Front Load Washer
The machine smells moldy...
I leave the door open after loads...still smells moldy...anywhere I need to look for sitting water or something that would keep this smell...hence my clothes smell moldy.
    President:
  • Frigidaire Master
  • 2,651 Answers
Moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Posted on Dec 03, 2008
How do I get the mold out??
Without a proper model number I would say you need to clean your washer with a product called Affresh or Washerfresh. If you don't wipe the door dry and the boot dry, also dry inside the boot between the tub and front of machine. Also, when you finish washing, open the soap dispenser or better yet, take the soap dispenser drawer right out between washings to to let everything air dry and leave the door open. If the smell still persists you will have to change the door boot. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky, moldy smell on clothes
I agree with your concerns, but, unfortunatly, leaving the door open and emptying the drain trap is all you can do. I would also start washing your laundry with at least a 1/2 cup of borox with each load. This will help with the smelly cloths as well as running the monthly clean cycle or an empty express wash with only bleach.
Jun 06, 2009 | Kenmore Elite 45986 Front Load Washer
Moldy smell
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The problem is design. Not all of the water is getting out after each cycle and not all of the soap gets fully dissolved. After awhile, this mucky slime gets 1n the drain hoses, pump and filter - and they all smell musty - especially when the machine sits empty with the door closed between loads.
You need to clean the innards of the machine by doing a load without clothes on hottest setting (Whites) and depending whether the smell is bacterial (add 1 cup White Vinegar), fungal (add 1 Cup Bleach) or clogged filter (add 1cup Arm and Hammer with 1/4 cup SALT), this should do it
(Vinegar for Bacteria, Bleach for Fungus and Arm and Hammer with SALT to soften and loosen the slime)
Choose from above (not all 3 at once tho) and fill the machine with water and let run without clothes.
I would do the A&H with salt first, let cycle complete, then restart and add a cup of Vinegar, tel cycle finish then redo with 1 cup bleach
After treatment, leave the front door open after doing laundry from now on so it can thoroughly dry out and get air circulation. - Just open, not WIDE open ;-)
Cheers!
Mar 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nasty moldy smell inthe MAH2400A
a cycle with just hot water and chlorine bleach will help but you may have to work at it a litle longer to get the door seal any cleaner in future run a short cycle with bleach and leave door open between use as much as possible..there is a new tablet shaped cleaner out now that may help in routine cleaning ckd with local dealer or repair personel also may ckd grocery shelf
Jun 09, 2008 | Maytag MAH2400A Front Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Washing Machine Smell
.I would try running some washer magic through it first. also when you finish a load a clothes leave the door open for a while to air unit out.Your unit is probally smelling moldy after each wash, leave door open to air out the tub You can get washer magic at your local appliance parts store.
Dec 01, 2007 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
1,834 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
