Question about Danby DDR606 Dehumidifier
I wish to purchase DDR606 dehumidifier. Will need to place a pump into bucket to send water up basement wall and out thru window. Will this work with this model? Thanx!
  • 61 Answers
This will work for all models. You just need to get a condensate pump. Hook drain from dehumidifier to the condensate pump. the dehumidifier will need to be higher than the pump so it can drain.
Posted on Nov 29, 2008
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
I have had my Danby ddr606 unit for 4 years in my basement. It has been running with a hose connected to it that allows the water to drain in the sump pump so I do not have to empty the "bucket"...
Yes. Either the hose is clogged or the hose connection and it's tubing is clogged. When that happens, water is automatically diverted to the bucket. The hose is easy to check for a blockage. Simply remove it and either blow thru it or look thru it for daylight.
To clear the hose connection and tubing. Use an 18" long appropriately sized Zip Tie. Insert the end of the Zip Tie into the hose connection and carefully work it in. You will reach a bend in the tubing that you need to gingerly work the Zip Tie past. Continue to insert it until the Zip Tie bottoms out or you run out of usable Zip Tie. The slowly pill the Zip Tie back out while rotating (twisting) it. This will dislodge any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Hook the hose back up, plug the unit in and turn it On. Set the humidity extraction level at 35%. Monitor the end of the hose for water flow, after about 15 - 20 minutes. If water doesn't start to flow, turn the unit OFF and repeat the above procedure. Also, remove the air intake filter and clean it if necessary.
Hope this helped to solve the problem and thanks for choosing FixYa.
Aug 03, 2011 | Danby DDR606 Dehumidifier
My Whirlpool dehumidifier runs, but compressor does not come on.......we do have moisture in the basement because the basement recently had a water problem.....and typically the compressor would come on....
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Whirlpool Dehumidifiers
My whirlpool AD70USS 70 pint dehumidifier won't run , it just beeps. There is power and the bucket is in place properly, The unit is clean and nothing is plugged and the fuse in the panel is ok
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The full light will not go off
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Dec 18, 2010 | Danby DDR606 Dehumidifier
My basement has condensation in the walls, but the dehumidifier won't turn on. It is plugged in and the bucket is empty. Not sure what the numbers have to do with the machine turning on, but I have...
heatman101
Aug 26, 2010 | Haier HD656E Dehumidifier
I purchased a lg dehumidifier last summer and now it doesn't take the water out of my basement. My basement flooded and my dehumidifier runs but nothing happens. please help I am desparate
heatman101
Aug 04, 2010 | LG LHD45EL Dehumidifier
Kenmore dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 11, 2009 | Danby DDR606 Dehumidifier - 60 Pints...
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Danby DDR606 Dehumidifier Logo
160 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
