Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire F/L Washer - Delay Start will not reset?
Washer 9 months old - has worked perfectly until now - When door closed the "Door Lock" light does not come on - when you press start we get 0' then 48 (Minutes to complete the cycle) I press Cancel and it displays 48, 60, 90, 1hr, 2hr ... the Delay Start button seem like it is stuck ( the the other buttons have a small "click" when pressed) should it release when Delay is canceled?
When we press any of the other buttons like Spin it rotates through the numbers same as when we press cancel
We even left the washer to see if the delay would work but nothing happened - I am at a loss as to why it will not work now
  • 1 more comment
  • Anonymous Dec 07, 2008
    Any body out there have an idea?
    Getting desperate enough to Call a repair man.
    Marg
  • Anonymous Dec 20, 2008
    I got a new Frigidaire Washer. It came stuck on Delay start as well. Calling the 1-800 number right now....
  • crazyfrogee Jan 03, 2009
    I have the same problem exactly. I am lost on what to do.
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
  • wash a lot Nov 03, 2011
    This was the best I came across saved me money thought I was going to have to call a technician ....it really works ...thanks a bunch
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
Front load frigidaire one year old and cycle won't start from one day to the next. The panel lights are indicating things are correct but the door lock light does not go on when I press start and the start...
I have had to change the door switch on every washer and drier I have ever had. Just a thought: If the door switch is bad the drier and washer will not start working. The one I changed on my drier about a month ago, when I opened the door and played with the switch while pushing the start button it finally came on. I changed the switch and no more problems. If the door is open the dryer and washer are not supposed to operate. I have changed some which you could not move around on those I would pull the wires off the door switch. Depending on if the switch is normally open or closed I would connect the two wire and try to start or leave them separate and try to start..
Nov 19, 2017 | Frigidaire GLTR1670A Front Load Washer
My friidaire washer will not start. The door lock light will not come on. The door closes properly. The error LOC comes on. Not sure what else to do. Doesn't seem to be any problem closing the door. Help...
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
May 23, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Dr error
DR is a Door open error .. you may have a faulity door lock.. first try to see if it is not closing right.. If all closes good the door lock is not to hard to replace... let me know what you find out?
Aug 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
2,413 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
