Question about Kenmore 61209 Microwave Oven
There is no power
There is no clock. There is no response when controls are pushed There is no light when door is opened. The microwave had been functioning perfectly well up to this point
  • Kenmore Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Posted on Dec 02, 2008
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Touch pad does not work when I push start but the light and clock and other features seem to work
please follow this steps for troubleshooting. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more:
Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Light is on when door opens but time(clock)and operating keys do not function.
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool Microwave Ovens
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa:
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
Keypad problem
The most likely causes are a bad door switch or a problem with the control panel assembly. You can find critical safety information plus our information file on checking and replacing door switches at our site, via our poisting here: If you need control panel repair, we do that for $32.50 nationwide.
Jan 24, 2007 | Kenmore 62622 Microwave Oven
Kenmore 61209 Microwave Oven Logo
80 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
