Please can you explain why the ink on the printer is only coming very lightly, more grey than black, have tried to tackle the instruction as you laid out, but nothing has happened, this was only recently and is very annoying as I am a writer and need my printer. Thankyou for your assistence. Ann G. Callender
    Scholar:
  • 126 Answers
Hello Ann.
In the properties of the printer you will have an option of how light or dark you want the document to print. Fo to the start menu, printers and select the default printer, right click and select properties. Look at the available tabs and find the printing preferences and you should see a setting to change this. Also there is a box that you want to ensure is not checked, it say's print in grey scale only. make sure this box is not checked.
Hope this helps.
Posted on Nov 29, 2008
    Sergeant:
  • 217 Answers
As there r some settings that has to be changed to print the proper dark black from your cartridges.but as an advise i will give you the simple solution just uninstall your printer drivers and then reinstall your printer driver again this will again set the proper settings to get the dark printout.and this settings will be set automatically you will not have to do any thing. if you dont have the printer drivers to install again after uninstalling Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung Konica/Minolta Xerox Panasonic
PLEASE NOTE
When installing drivers/software it is generally a good practice to -
·                                 Delete old/previous installs
·                                 Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
also this another link
for hp printer drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305980&lc=en&cc=us&dlc=en
I seem unable to get the black ink to work?? the grey and all the other colors are working but not the black?
there are only 4 colors in a printer one of which is black
grey is very light spray of black
to get the spectrum of colors one of the mix is black
check the printer head for black and is there enough black ink in the cartridge
Dec 24, 2015 | Epson Stylus Pro 9600 InkJet Printer
Every time I print there are grey squares all over the page
Hi Levi,
Call ,,,, !-800-539-6275 - explain the problem and they will assist you.
Regards,
Dennis
Sep 04, 2014 | Lexmark Pro 915 All-in-one Printer W/inks...
I replaced the black ink and the error light is on and the out of black ink light is still on. Won't print
Try it.......
Remove the print head and soak it for three 5-minute cycles in hot (~170 F) distilled water about 3/4 inch deep with continuous mild agitation. The first soak quickly turn the water black, the second end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink passages from the cartridges to the ink ejection part of the print head.
Carefully dry the print head as per instructions, clean the electrical contacts on the printer, and placed the print head and the ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Dell 1320c Laser Printer
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Light grey or no black printing at all!
barb i suggest u call kodak support for a new printhead
their number is 1-800-235-6325
Aug 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Printing only in grey
Can you do simple copies in b/w without probs?
If yes, you might have checked the greyscale at the printer settings.
If no, do a quality test print (pressing ink etc.). If you cant read the instructions in black, the ph or circuit board is defectiv.
Dec 05, 2007 | Brother MFC 240C All-In-One InkJet Printer
k24674
jasbo
jasbo
Marvin
Marvin
