Question about Sony CMT-HP7 CD Shelf System
MECH Error Evidently a CD is jamming the mechanism. Sending it to the shop would cost more than it?s worth. Can I fix it? Can someone recommend a place to buy a repair manual? It seems like a waste just to trash it. Thanks
  • 1 more comment
  • prashanth149 Dec 10, 2008
    Evidently a CD is jamming the mechanism. and does not eject or read the CD. gives me an error "MECHA ERROR"
  • Anonymous Dec 14, 2008
    I am getting a MECH error where Disc 2 seems to be jammed. I removed the side panels and sprayed compressed air, and I still can't get any response from the stereo. Are there any other suggested solutions?
  • trs11758 Feb 04, 2009
    need replacement belts for cd. 1 controls the play and 1 controls the 5 disk elevator mechanism..where do i get these replacement belts? respond to trs11758 at yahoo.com
  • 3 Answers
Worked. thankssss!
Posted on Jan 19, 2008
My cds were stuck too i had it plugged to an extension cord and then moved it to plug into the direct outlet no extension and it started working again took out all the cds. it worked for me hope itll work for you too. thats if you have it hooked up to how i had it....
Posted on Dec 19, 2008
I had a similar problem.
Remove the side panels and spray compressed air.  Did the trick for me.
Posted on Oct 21, 2007
SOURCE:
"CDC MECH ERROR" on 2009 Honda CR-V EX-L with Nav
Either the unit's motor is bad or the mechanical parts are dirty not allowing the unit to change CD's or load them.
Jan 23, 2014 | 2009 Honda CR-V
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
MEECH ERROR
MECH ERROR or "MECHanical Communication ERROR"
When this message is displayed on cd player, indicates that there is a problem with cd player that has do with the mechanism which is jammed up.
You will need to take off and open up your player and clean out the dust inside.
Hope helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 24, 2011 | Car Audio & Video
Cd player shows error "Mech"
MECH message means a "mechanical communication error", when display on your car cd player indicates that there is a problem with cd player that has do with the mechanism which is jammed up.
You need to open up the player and clean out the dust inside.
Good luck.
Oct 12, 2011 | 2007 Dodge Nitro R/T New Cars
When I turn on my camera I get the error message 0x0311how do i fix this?
0x0311 error is evidently a lens error.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 11, 2011 | Sanyo Cameras
Hi,Have got got a canon(powershot a710 is) whenever i turn on the camera i get a few beep noises and the screen remain black with the message'lens error,restart the camera'....and it then turns off.....I...
The lens is jammed. Usually dust or grit gets in the mechanism and causes it to stick. Could try blowing down the side of the lens but it will probably need taking apart and cleaning. It is not an easy job to do but it might be worth trying as it would probably cost too much taking to a repair shop.
Jan 02, 2011 | Canon PowerShot A710 IS Digital Camera
I can't get my CD Player to open
The cd mechanism is very hard to get to in this model but sometimes through the bottom panel
(if one)! Maybe some gears can be seen to turn
in mech. These systems are usually not worth fixing
but you can "luck out"!
Apr 17, 2010 | Crosley Celebrity CR73-3 3-Disc CD Player
Same thing
this unit needs a mechanical alignment, I have worked on enough rca's to last a lifetime...the cd tray is not chucking properly//it should load and you should hear the cd mech chuck down..if it is not chucking properly..it will open randomly..you can fix this by jamming it shut with the power off
Jul 28, 2009 | RCA RS1289 Shelf System
Sony mhc-GX450 mech error
unplug the system.take out any extra speakers,and try plugging it back in.
Feb 24, 2009 | Sony MHC-GX450 CD Shelf System
Disc wont change....or play....
e-mecha appears to be nothing more than an interlock. hitting reset clears the interlock, but if the problem has not been fixed, then the interlock will trip again, preventing operation. Determine why the radio goes into mechanical failure to begin with. Once fixed, the interlocks will be made and the radio will play. There are a number of events that all have to complete sucessfully including feedback from sensors to maintain the e-mecha interlock. One of your sensors is not being made, either by a sensor problem or by a mechanical issue that prevents the sensor from tripping. -Steve
Oct 22, 2006 | Nakamichi MB-100 6-Disc CD Changer
Sony CMT-HP7 CD Shelf System Logo
783 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
