Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
I have a Hot Point refergerator. It started leaking from the bottom of my frig. I can't find a drip pan, I feel this pan is full. Do you know where it is located? Thanks ...
    Scholar:
  • 131 Answers
There is a kick panel (somtimes this is a vent)on the front of the unit,with the door open you should be able to pull this off(most are held in place with expansion clips)your codensate pan is behind this & should just slide out,most are plastic,so be careful not to break it.hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
What is the dripping pan ????
Under the frig front bottom kick panel about 3 inch high and runs all the way across the bottom of the frig. remove it and the drip pan is located inside.
Mike
Mar 23, 2016 | Refrigerators
Why is there Water on floor,and ice in bottom of freezer?
Under your frig there is a drip pan that's most likely full and check your drain tube also for clogs probably Iced up. You access the pan from the front bottom.
Hope this helps Mike
Jun 14, 2015 | Maytag Refrigerators
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
The fridg has a pool of water under the front door that keeps appearing even after we wipe it up. It has suddenly appeared today. It is a Silhouette 442 Frost Free model.
check drip pan under frig.remove ft bottom of frig under door/ck drip tray?full? old frig?-time to buy new one.could be working to hard(age,compressor going bad)will cause frig to sweat.producing water under it.hope this helps.:)
Nov 24, 2009 | Lands Phones
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
Water draining into frig
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 06, 2009 | GE GTS22KBP Top Freezer Refrigerator
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
Apr 19, 2009 | GE Refrigerators
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Nov 29, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
