Question about Magic Chef 9522 Electric Double Oven
MAJIC CHEF DOUBLE OVEN NOT WORKING
Hello, I have a majic chef double over model 968-4clx its an older model around 20-25 years old, the bottom oven works great but the top oven stoped working today, when you turn the knob the red light wont come on, I had to replace the burn element last week, could that have done something? thanks brad
  • dlegere Dec 05, 2008
    This same thing happened to me at almost the same time. How did you fix this? Do you happen to have the dimensions of this model - I'm searching for a replacement oven. Thanks, David
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Posted on Dec 18, 2008
I want to thank 'twocylndr_h' for his posting from 12/18/08 that described the same problem I was having and the fact that messing with the time bake start/stop dials restored the functionality of the upper oven's thermostat/switch!
Posted on Apr 12, 2010
  • forgiven_4 Nov 29, 2011
    Thank you! I reset my timer controls & my oven now works again
Thank you...same problem here with older mobile home, Magic chef, double electric oven. Only thing is that I'm not sure what I did when I tinkered with those knobs and even tho~ I got it working this time....with no manual...it's bound to happen again! So frustrating!
Posted on Oct 16, 2011
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
C clock will not stop buzzing. 15 year old magic chef oven. do not know model number because manual does not identify it. the only thing I have is a number at the bottom of the installation manual. Not...
Beeping from ovens is an indication of function buttons in user. Observe the entire feature function either as cooker still in operationality where beeping is warning as haven been completely secured from functionality. Refer with an expert with condition over impressive.
Mar 01, 2011 | Magic Chef Ovens
I have amagic chef gas appliance serial #3x 886115 model#7211w-5bw. can the top half be removed so that the bottom still functions???
No...while there are two ovens... the frame and most of the controls are common...so that you cannot eliminate one and still have the other work...
technically it may be possible but the cost would be more then a new oven...
heatman101
Jan 11, 2011 | Magic Chef 9112 Gas Double Oven
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
Missing my manual
I suggest you read this link before you use the self clean cycle. http://www.fixya.com/support/t241114-oven_will_not_heat#SameProblemContinued
I used mine for the first time two days ago on model KEBC147 and it will not heat now.
You might not want to try self-clean unless you have time to call for repair afterwards before
using your oven again.
Very disappointed in KitchenAid in Texas ...
DBN
Oct 24, 2008 | Magic Chef 9815 Electric Single Oven
Unable to find pilot light for m,ajic chef oven
its electronic ignighters is it plugged in and have you tried turning it to light new ones dont have piolets
Jul 13, 2008 | Magic Chef Ovens
Magic Chef 9522 Electric Double Oven Logo
1,002 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
