Question about AEG Lavamat 16810 Front Load Washer/Dryer
I have a frigidaire front load washing machine
The door won't lock. We can't clear the panel to start over. All lights blink then it says err and loc
    Sergeant:
    Champion:
  • 272 Answers
Sounds like it needs replacing from what you have said. You could try to free up the locking mechanism by going behind the lock on the washer from the top and the door catch. If this fails to solve the problem, then you will need to buy a new unit. You will get one online from Seme Nedis Ltd. You will should find the washer model number on the outer edge of the door. I hope this has been of some help to you.
Posted on Nov 29, 2008
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My washing machine won't start
Dec 29, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
MY fridgadaire lg washer says loc and wont let the door lock and machine start
That is a door lock malfunction, check the lock and wire harness connections.
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
AEG Lavamat 16810 Front Load Washer/Dryer Logo
81 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
