FixYa.com
Tags:
Dell M990 19
Display completely flipped to side (by 5 users)
posted by shlomo on Jan 18, 2007
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by pduffyd, posted on Jun 03, 2008
Had a similar problem, but it was my fault. I got up from my desk one day and put my fat hand on the left hand side of the key board, and pressed a few buttons at the same time, looked at the screen and it hard rotated 90Deg.
Went into properties on the desktop and adjusted the screen setting back to normal from 90Deg.
Don't know if this helps
Comment by Guest, posted on Mar 29, 2008
Yes and I don't know what to do I have a headache
Comment by Blaq, posted on Nov 14, 2007
my screen is displaying sideways
Comment by Guest, posted on Nov 07, 2007
I am having unpredictable results with my new fpd2275W 22 inch monitor. Sometimes it doesn't start up when I turn on the computer (or shows black). Yesterday the horizontal tracking was off in one direction and today the other, then restarted the computer and it was fine. Should I return it, is it defective? Or is there something I'm doing wrong in the setup. I am using a vga adapter to my computer.
Best Solution
posted on Jan 21, 2007
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2385 votes
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the video / signal circuit board inside the monitor.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 01, 2007
Thanks for Trying (70)
vrgruver
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
Alt-UpArrow
You pressed Alt-SideArrow at some point and the video card rotates the image.
-or-
You have a monitor that rotates and auto rotates the image to change from landscape to portrait mode. You need to probably just rotate the monitor on its' stand and reset this feature.
Solution #3
posted on Jan 22, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
this could also be that you have hit ctrl-alt-(arrow key) in XP and flipped your view.
this is for tablet pc's but works in some cases in XP on desktop PC's.
Solution #4
posted on Jun 30, 2008
Not Rated (0)
shenderson
Rating: 0%, 0 votes
To correct for the sideways picture, hold the CTRL key and press the arrow keys at the same time until it is right side up.
Solution #5
posted on Jun 26, 2008
Not Rated (0)
halospawn0
Rating: 100%, 1 votes
ha yeah i used to do this all the time, ok u press ctrl+alt+up arrow key
it will rotate ur screen.. make sure u click on ur desktop first and then press it
Solution #6
posted on May 06, 2008
Not Rated (0)
whisk3rz
Rating: 0%, 0 votes
Control+Alt+Down Arrow may solve this, as well. Some computers have the capabilities to flip the display to the side or upside down using such commands.
If this flips your screen upside down, then I've got it mixed up, and try Up arrow instead.
Solution #7
posted on Apr 23, 2008
Not Rated (0)
Neilly B
Rating: 0%, 0 votes
Ive just encountered the same problem and was convinced this was to do with the monitor , when in fact after searching I have discovered that XP has a feature built in whereby if you press ctrl alt and direction keys it alters the screen orientation , this has solved the problem for me, worth trying if using XP, not sure about other OS's.
Good Luck
Neil B
Solution #8
posted on Mar 05, 2008
Not Rated (0)
masoud1362
Rating: 0%, 0 votes
my monitor width is low and dark display .
I can't increase it because not work
Solution #9
posted on Nov 15, 2007
Not Rated (0)
shivam4529
Rank:Wiz Wiz
Rating: 74%, 75 votes
open your pc and clean all the dust your problem automatically solved it is because i have the same problem now it is alright
Solution #10
posted on Sep 21, 2007
Not Rated (0)
ajith
Rank:Guide Guide
Rating: 85%, 27 votes
if the data cable front pannel controls are ok the only problem is inthe horizontal section specially in the deflection circuit
Solution #11
posted on Sep 18, 2007
Not Rated (0)
Buzzard
Rating: 82%, 13 votes
This happened to my neighbor's monitor, and I looked and looked for troubleshooting info everywhere I could think of for an hour with no luck. Finally, I just stumbled upon the incredibly simple solution just by trying a lot of keyboard combinations. Simply hold the "Control" and "Alt" keys down together, and while holding them down, click any of the 4 directional arrows to move the image in the direction of the arrow. It's actually kind of fun to mess with friends by doing that to their monitors...just don't prolong the agony, lol.
Solution #12
posted on Apr 29, 2007
Not Rated (0)
density
Rating: 0%, 0 votes
lol. This can easily be fixed by pressing ctrl and the direction button like left, right,up, try that and it should be fixed, it only works on some computers though so I am not sure if it will do anything on yours. it is obviously not a monitor problem.
This Problem Also Relates To: HP Compaq FP 7317 17 in. Flat Panel LCD Monitor HP f2105 (Metallic, Carbonite) 21" LCD Monitor HP HP / Hewlett-Packard RY117AA w2408 24" Widescreen LCD - VGA/DVI-D with USB Hub LCD Monitor HP 2025 (Carbon, Silver) 20.1 in. Flat Panel LCD Monitor HP 91 (White) 19" CRT Monitor Philips 170P (Silver) 17" LCD Monitor HP vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor
Can you Help with these Monitors problems?
Monitors
22" flatron (W2252TQ)...
I have two problems. I was... Answer This...
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
