Question about Sony KV-27V36 27" TV
Sony TV 27" KV-27V36
When the power switch is turned on, the red power light blinks but the picture doesnot come on the screen. Please tell me what the problem is and how much it may cost to fix it. Thanks.
  • wrgm2002 Jun 30, 2008
    El TV enciende, tiene sonido normal, la luz roja frontal parpadea, pero no hay video. La pantalla permanece oscura.// The TV lights, it has normal sound, the light red frontal it is blinking, but there is not video. The screen remains dark.
    Scholar:
  • 168 Answers
The symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician. i cannot tell you the cost to fix your tv coz my location is in the Philippines.
Posted on Jan 19, 2007
SOURCE:
I need the user maual of Sony KV-ES34M80 in PDF format. As I have lost my original manual
Hello
What do you want? User manual for Sony kv-27v36; or service manual for kv-es34m80? Clear your post please.
OK.
Dec 22, 2010 | Sony KV-27V36 27" TV
Looking for part 859796900 for the Sony KV-27V36 27" TV. Apparently that's the transformer. No one seems to have the part, including Sony! TV is 10 yrs old and kaput without it. Help?
What Transformer is that? It doesn't sound like a Sony Part #
The flyback transformer fir this model is listed below:
1-453-207-11 TRANSFORMER, FLYBACK NX-2609//X4C
Oct 26, 2009 | Sony KV-27V36 27" TV
Sony KV-27V36/ No Picture
could be just a fuse or then again if its a plasma the light could be out either way to avoid getting shocked see a tech
Jun 30, 2008 | Sony KV-27V36 27" TV
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Sound, but no picture
Locate vertical output IC = solder all pins = two off-set rows,
then try again................part location IC301 , or 401 ?
2) possible bad CRT = turn up screen voltage slightly = did pix pop back on ?..................................T.
Please rate this solution.........................
Feb 09, 2007 | Sony KV-27V22 TV
Sony KV-27S42 not on but timer flashes
The blinking light means almost 100% that the high voltage circuit has failed. Probably need a new horizontal output transistor and flyback. Perhaps an associated resistor or diode. If you have the expertise go for it, otherwise take it to a professional. In any case be extremely careful and safe. Good luck.
Jun 21, 2006 | Sony KV-27S42 27" TV
SONY KV-27V36
bad crt or crt socket
May 26, 2006 | Sony KV-27V36 27" TV
SONY KV-27v36
this problem would be in your power spply or the sweep derived power supply. probably a bad capacitor or regulator IC/transistor. Unless you know how to trouble shoot electronics them please have this set looked at by a pro. Good Luck
May 25, 2006 | Sony KV-27V36 27" TV
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
