Question about Iomega (32961) External REV Drive
Iomega Rev Disc Write Error
A new error for an existing working disc appears when I now try to save a file to the disc. The error message is "Burn to Disc - Please insert a writable disc into drive E:". I am able to read files from the disc. I am able to write to other discs with the same drive.
  • Iomega Master
  • 27,725 Answers
You might have finalised the disc on the first burn or you have not selected to burn a multisession disk
hope tis helps
Posted on Jun 08, 2012
5 Suggested Answers
SOURCE:
Krenn
  • 59 Answers
SOURCE: disc won't read
what type of zip disk are you trying to read? if it is larger than 100MB, the drive will not be able to read it.
can you read other disks? can you see the drive in my computer?
what operating system are you using, and how does does this drive connect to the computer? USB? Firewire?
Posted on Mar 29, 2008
SOURCE: Iomega Zip 750 Drive
Straighten a paper clip and insert it into the little hole on the power button. You have to stick it in there kind of far, but you'll get your disk out.
Let me guess, you both are Mac users. Probably upgraded to a new Mac OS? Now it looks like your zip drive has died.
I'm working on fixing this same problem. The new Mac OS won't detect the Zip Drive and the classic environment isn't supported.
Posted on Nov 05, 2008
anasourabh
  • 202 Answers
SOURCE: I have an iomega zip 100 external drive. When I
ur zip drive heater were not work properly, kindly check & clean it, or replace it
Posted on Nov 28, 2009
  • 56 Answers
SOURCE: Hi I saved a music file on iomega 70 disc bit
Is the Disc Lock switch on If so it will not let you change it
Posted on May 09, 2011
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
I have a 500GB hard drive that I am using with a Mac OS X 10.5. I have been working with iMovie file that are several GB in size and I can't save them onto my iOmega hard drive. I have tried starting a new...
First of all I would check what the file system is on your iOmega drive. If it is FAT32, then it will be unable to handle any files over 4GB in size.
If necessary, reformat it to a Mac friendly file system and retry.
If this doesn't help, please repost your problem including the exact text of any erro messages that you receive.
Hope this helps!
Jun 29, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
None of my games are working, they all say unreadable disc. I bought a new game to see if it was the xbox and it said unreadable disc as well what do i do?
# Turn console off and then on. # Clean the disc and examine it for flaws or scratches. # If this behavior occurs with one or two discs, search the Microsoft Knowledge Base for the specific game title(s). If you find a known problem, follow the information outlined in the article. # Delete the appropriate saved games. See Note 1. Copy a saved game to a Memory Unit (MU) if you have one available. # Try three other games, and then try the original game again. # Try the game on another console if possible. # Replace the disc at retailer. # Repair the console Note 1 If a saved game file is corrupted, it can produce a disk error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disk error message with more than two games, this procedure will likely not resolve the issue. Another trick to try is to turn your console so its vertical( sometimes works)
Jun 04, 2009 | Microsoft Xbox 360 Console
Error code 3102ED-14-00000000
The problem may occur when a temprary file "TempFile.tdi" already existed.
Try once more after removing the file or changing temporary folder.
Ichiro from Japan
I'm not concerned with Toshiba. :-)
Feb 19, 2009 | Toshiba Satellite Pro A200-EZ2204X...
A file won't open because of disc error #3
Take it to an expert or buy a new disc if you can
Dec 18, 2008 | Inspiration Kidspiration 2.1 for PC, Mac
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
Iomega CD-RW 52x24x52 External Burner wont burn
have you checked the web site for drivers update and which burning software are you using if you are using on board xp stop using this and got for nero burning if you are on xp sp1 and try and upgrade to xp sp2 or win 2000 sp4 and clean cd lense and try that if same resaults it's time to redo windows as you may have currupted dll files and change usb leads over if possable
Aug 13, 2007 | Iomega (32885) CD-RW Burner
Iomega (32961) External REV Drive Logo
141 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
