Question about Curtis DVD5091 Theater System
Speaker volume too low,can we by pass dvd player and just hook up
Speakers directly to tv.??
  • anthony98453 Dec 26, 2008
    i just got this system. i hooked it up and did everything correctly. i turn on my TV and i can barely hear the sound. when i turn off the system the sound is extremely loud.
  • casjam42 Dec 26, 2008
    i cant get sound by just watching tv only when i watch dvds what is wrong
I have no sound through tv only the dvd
Posted on Dec 26, 2008
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
I have a coby CSP96 speaker system. it said on the manual online that i found on the cobyusa.com site that there should be a volume control on top of the sub-woofer but there isn't one there. i can only...
I am having the same problem. I also have the combo dvd and theater system. I also read that the sub woofer is supposed to have a volume control on it but its not there. The only way to control volume is to connect to coby dvd player. This dvd player is beyond terrible. DVD looks bad and sound is miserable. I hooked up xbox 360 to my samsung 52 inch, then on the outputs of my tv into the inputs of the "TV" section on the Coby Sub woofer. At this point great sound quality comes from the xbox and all speakers, but the volume is uncontrollable and is blasting loud. Tv volume control does not work either. I am stuck like chuck and have not found a solution. This has to be one of the worse purchased i have ever made because i am forced to use a terrible DVD player just to get some sound through the speakers. I dont understand why on the speaker systems you buy without dvd combo has a volume control on subwoofer, but on the combo subwoofer doesnt have it. Just terrible. I will continue to look online and try and find a solution other than smash it to bits.
Oct 19, 2010 | Coby CSP-94 Speaker
I have 7.1 speakers attached to my receiver, I am using 16 guage wiring and yet I still find the sound in some movies is very inaudible..almost tinny unless I change the audio to 7 channel stereo. My two...
There are a multitude of user settings that can affect the apparent loss of bass you describe. Since you mention it is relevant to a soundfield choice that sort of eliminates hardware problems.
Find the SET Menu and set everything under SOUND according to your actual speaker configuration. For the purposes of set up, consider the word LARGE to mean "CAN handle substantial low bass" and SMALL to mean "would distort or be destroyed by substantial low bass".
Under LFE/Bass Out, the Front/Both setting addresses the sharing (or not) of Low Frequencies with Large Front speakers. I recommend BOTH if your front speakers have large woofers or are otherwise bass-capable (since physical size isn't everything).
Run through the speaker Distance and Level adjustments. The LFE/Level will have a huge effect on perceived bass so check it out.
Check the Dynamic Range. It's vague about what optimim is, but avoid using MIN. I'd try MAX or STD for expected loud listening.
Run Low Freq Test to match the sub to your other speakers.
There are lots of opportunities in this beast for MALadjustment. It's your responsibility to understand the settings you select.
Dec 05, 2009 | Yamaha HTR-5790 Receiver
CAN I PLAY THE DVD PLAYER WITH SOUND THROUGH MY TV WITHOUT HAVING THE SPEAKERS CONNECTED?
You can set up your tv in this way. Hook up your dvd player directly to your tv and then hook up your surround sound reciever from the audio out jacks from the back of your tv. This should allow you to use either your tv volume or the surround sound feature. Hope this helps
Oct 21, 2009 | Samsung HT-Q40 System
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
I have BOSE speakers plugged into a small lcd tv. when the tv is off, I'm still hearing cable audio. why? i'll clarify. my tv has rca jacks connecting it to a couple of small bose speakers. sounds...
Your TV output is a pass-thru from the coax cable then. The only solution- turn the volume down, or unplug them.. Or get a cable box. A VCR may work as a temporary cable box, and if you have a remote for it, you should be able to just turn off the audio at any time with a VCR remote. (unless the VCR also has a pass-thru only audio output)
May 25, 2009 | Audiovox DVD Player FPE1505DV
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Nov 01, 2008 | Televison & Video
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Curtis DVD5091 Theater System Logo
293 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
