Question about Insignia Digital-to-Analog Converter for Analog TVs
I have Rabbit Ears on an analog TV using a Zenith digital converter box. But how do I tape a TV show on my VCR that I'm not watching? I purchased another digital converter box to attach to the VCR but what additional equipment do I need for this set up?
    President:
  • 2,992 Answers
The only way you can tape a different show than you're watching is to do as you have done: purchase a second converter box and connect it to the VCR as you did with the TV. You can pick up a device called a splitter which will allow you to divide the antenna signal between the two boxes.
There are some problems with the splitter arrangement. If you need to adjust the antenna position to get a good signal on one channel, like the one you want to watch, that may mean it isn't in the best position for another, like the one you want to record. You might need two antennas for the best performance.
Also, you can't program recording on different channels at different times unless you'll be home to change channels on the converter box. The VCR will only find a signal on channel 3 or 4, depending on how you set up the box, and you'll always record on that channel. The TV channel you record will be chosen by the converter.
Finally, you need to connect both the VCR and the converter box to a single antenna connection on your TV. There are two ways to do this. One is to use a splitter again. Normally they are used to split a single antenna input to two ouputs, but they can also combine to inputs into one output (basically you just use it backwards). Connect the ouputs from the box and VCR to the splitter's output connectors, and then go from the splitter's input connector to the TV antenna connector. This arrangement may not give the best picture quality, though. An alternative is to use an "A/B" switch, which allows you to choose which source connects to the TV.
It sounds more complicated to hook up than it actually is. It is more complicated and less flexible to use this setup than it was before the switch to digital broadcasting, but they call this "progress."
Hope this helps. If you need more information, just post a followup comment!
Posted on Nov 30, 2008
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Taping digital onto a vcr
You'll need to connect the VCR to the converter box and then connect your VCR to the TV. ou can get a diagram showing how to connect everthing at www.dtv.gov; there is a section with publications that has a document on how to hook up your VCR to tape the show your watching or watch one show while taping another.
Mar 14, 2009 | Insignia Digital-to-Analog Converter for...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
May 13, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
111 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
