Question about Epson CX4600 Stylus Color All-In-One Printer
My printer is not working
Hello, mt epson all in one printer is not printing or copying at all. Can this problem be fixed? If so how do I fix it? Thanks
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
Inky
  • 691 Answers
SOURCE: epson stylus photo r220
This seems like you have two separate errors.
For the loss of ink problem, see my previous posts about under head cleaning. This should get you going again, but if not, there is another known issue which causes these machines to stoip printing. This problem stems from a manufacturing "feature" which results in a broken pipe. To get a fix for this you should contact http://www.TheServiceManualShop.com and ask about there countermeasure for loss of ink in the Photo R series
The second error with the flashing lights depends on the sequence in which they flash. If the power light is off and the Ink and Paper lights flash half second on and half second off but alternating, then you have a maintenance request. This is easy to sort with yet another kit from The Service Manual Shop (R220 rescue kit)
If the sequence is Power light off but ink and paper flashing simultaneously then you have a fatal error. These are somewhat harder to attempt to fix and may require specialist knowledge and big parts that put the machine beyond economical repair.
Having said that, it can be worth taking the machine apart and removing the ASF assembly then reassembling as sometimes the feed mechanism ties itself in a knot and throws up a scary error.
Hope this helps a little
Posted on Oct 13, 2007
SOURCE: EPSON FX 2175 always printing JL 1284.4 @GJL
sometimes the printer head is locking/stopping at the right side
Posted on Feb 05, 2009
  • 15 Answers
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Posted on Mar 01, 2009
Sebin
  • 712 Answers
SOURCE: Epson CX 4300 printing problem
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Posted on Feb 19, 2010
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
I have had this problems before and I don't remember what I did to fix it. I have checked the default paper type and worked with the margins to no avail. The footer is also cut off in print preview. Any...
my printer was epson dx7400
iv loadednew inks genuineinks cheta putpoweron printer load ok but was flashing light
look ikns mt iv try inks no t012 t013 t014 t011 that was £45.00
stillnot working
try compatibe inks the same nothe same was still not working
im sorry iv had astroke as myproblem is worying my head
thanks fire16
Jan 11, 2011 | HP Office Equipment & Supplies
Epson 9500 Print head is not working
hello
I was wondering if you have solved the problem.
If not, please contact me and I will let you be satisfied.
Jack
E-mail:inkbiz@szprintmedia.com
MSN:Jack_yu0813@hotmail.com
Apr 06, 2009 | Epson Office Equipment & Supplies
Printer printing more then what is needed
while uninstalling the epson driver it will ask you for delete the setting or do you want to keep it. if you select keep it, it will happen how many times you install the driver. Check the printer settings in printers and faxes window, select printer go to printing preferences, page layout and check whether you give no. of copies to 2 there.
May 06, 2008 | Epson RX595 Photo All-In-One Printer
Copy feature on Epson CX 4800 doesnt' work.
call epson and tell them your problem, the can help you, most of the time epson will replace the printer for you for free.
Nov 28, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX4600 Stylus Color All-In-One Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
