Question about Acer (56.04145.901) (5604145901) Power Supply
Problem with battery or power cord?
Acer laptop. Is it the battery or power cord....the cord gets hot....and when plugged in it changes to charging and then to not charging? I have to move the cord around before it chargers ....to I buy and cord or battery?
  • 4 more comments
  • Anonymous Jan 11, 2009
    i woke up one morning and the cord was not charging and the battery was like dead if one of u could find a way to fix it thats easy that would be cool
  • djdcorvette Feb 15, 2009
    My dog tripped over teh power chord to my Acer laptop and it fell to the floor .I turned ti on and it started up and seemed fine until the battery died and it will not charge or start up. Need help!
  • Anonymous Feb 23, 2009
    battery won't charge
  • Anonymous Feb 25, 2009
    I have to move my cord arund and hold it in one spot till its fine. but now it wont do nothing at all and my computer is dead.
  • gazhayes Mar 05, 2009
    Had my new laptop for 2 weeks. I have to wiggle the power cord to make it work, the round DC power cord where it connects to the converter box (black).
    I have an Acer aspire one.
    I opened the power adapter to take a look since I was a TV repair guy before and know what I'm looking for. The soldering joints are about what a 12 year old kid does when they first learn about electronics! Horrible. Cheap piece of worthless cr*p. What did I learn? DO NOT BUY ACER.
    I will contact acer for a replacement but I doubt they will do it because I opened it up, why did I open it up? Because I have a business to run and don't have time to mess around with dodgy equipment produced by dodgy companies.
  • Anonymous Mar 26, 2009
    I have an Aspire 5735Z and it suddenly stops recognizing the power connection. It will beep and flick between "battery" and "plugged" power modes erratically. Moving the cord helps sometimes, but it is firmly plugged in.
Its on the inside of the laptop... mine does that and it got to the point where the plug melted... warrenty doesnt cover that (so i just found out) and my new cord does the same thing.
Posted on Jul 31, 2009
  • 395 Answers
It could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Posted on Nov 30, 2008
I have an acer aspire 5920 and you i try to charge there is no power not a light on it goes on what is the problem thank you
May be your power cord. Make sure it's plugged in at the middle near the inverter box... ( that rectangular black box that gets hot in the middle of the cord) as well as at the computer and the wall, or if surge protector, make sure it is on and not tripped. If not you need either a new battery, power cord, or both
Jan 04, 2015 | Acer Aspire 5920 Notebook PC
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Battery
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
Adapter
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
http://support.acer.com/us/en/default.aspx
http://www.solarum.com/2010/01/03/acer-aspire-battery-not-charging/
Jul 14, 2013 | Acer Computers & Internet
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Battery not charging on aspire 5736z
  1. Install the BIOS. (from acer website)
  2. Reboot, log back on, delete the "Microsoft ACPI-Compliant Control Method Battery"
  3. Shut down.
  4. Removed the battery, unplug the power, waited a few minutes, tapped on the keyboard with voodoo chicken feet.
  5. Plugged it back in without the battery, booted it
  6. Logged on, deleted the ACPI driver again.
  7. Plugged the battery back in (hot, not shut down)
  8. Rescanned for hardware changes.
Mar 22, 2012 | Acer Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Please post the step by step process of turning on my laptop acer 5570z.. (powerswitch problem) thanks in advance and more power
Hi
Have you plugged in your power cord to the electric socket so that you can charge the battery
using the laptop with the power cord in while it is charging
so if there is not charge in the laptop at all maybe plug in and turn on socket switch
and leave to charge for an hour or so
then try to start laptop again
hope you can sort it
good luck
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Acer power cord
if you can use your notebook without the battery with the power cord attached, then the battery ist defective. If your notebook doesn't power on at all without battery, then the power cord is faulty.
Jul 23, 2010 | Acer Aspire One PC Notebook
How do I charge the battery on a new Acer Aspire One Series?Netbook
Just plug the computer into the wall with the supplied power cord (while the battery is in the computer). This will charge your battery.
Sep 22, 2009 | Acer Aspire One A150-1006 Notebook
Acer TravelMate Laptop, cord getting hot, not getting power
I would imagine the voltage regulator in the adapter brick it dying...it will fry your motherboard if it starts throwing off power spikes. laptops need good consistent power flow of the right voltage. Buy another adapter.
Sep 05, 2009 | UltraLast ULAC3660L For Acer Aspire...
Computers & Internet Logo
1,735 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
