Question about Epson Stylus Photo R200 InkJet Printer
Epsom R200 i need a epsom stylus R200 status monitor for vistor i can't check the ink levels
  • christoph413 Nov 30, 2008
    THANK YOU FOR THE SOLUTION TORANJ PRINT,BUT I CAN NOT UNDERSTAND THE LANQUAGE, COULD SOMEONE TRANSLATE IT FOR ME!!!!!!!!
THANK YOU FOR THE SOLUTION TORANJ PRINT, BUT CAN NOT UNDERSTAND THE LANQUAGE,COULD SOMEONE TRANSLATE IT FOR ME!
Posted on Nov 30, 2008
سلام دوست عزیز
شما میتوانید لوح فشرده راه انداز پرینتر خود را داخل دستگاه گذاشته و دوباره اقدام به نصب پرینتر کنید
فقط پرینتر قبل از نصب حتما خاموش باشد و وقتی پیغام مورد نظر را مشاهده کردید اقدام به اتصال کابل USB کنید
با تشکر ترنج پرینتر
TELL: 0098 311 2683688
FAX: 0098 311 2660477
Posted on Nov 29, 2008
My epsom r200 has both red lights flashin when i turn it on how do i cure this prob?
Please check all of the printer doors are closed. If it is closed properly check the cartridge. If the ink is low please change the cartridge.
Aug 06, 2010 | Epson Stylus Photo R200 InkJet Printer
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Feb 02, 2010 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo R200 status monitor in Windows 7 is'nt highlighted ink is low can't tell which ones
Uninstall the current driver and Status Monitor, once uninstalled connect and power the printer on to install the Windows 7 In box driver. If that does not work then you can tell which cartridges need replacing using the printer itself. Lift the lid and press the red ink button once. The carriage will move to the left and stop by a pointer. This will point to the cartridge that needs replacing. Repeat until it is in the change and then change the indicated cartridge/s and then press again to complete the change.
Jan 27, 2010 | Epson Stylus Photo R200 InkJet Printer
Status Monitor isn't hihglighted so I can't check
This can only be done by getting a new status monitor software . Follow my instructions:- STEP 1 - Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site ( http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html ).
STEP 2 - Open the Epson StatusMonitor program in any application (such as wordprocessingmag-glass_10x10.gif, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application.
STEP 3 - Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
STEP 4 - Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
STEP 5 - Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
STEP 6 - Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Aug 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Ink level
i used Epson R230 inkjet printer.Now the printer, two lights are blinking .the messge show service requird .
Aug 04, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
170 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
