Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch condenser dryer
Just got this unit and it doesn't heat up i have tried little red reset switch still cold any advice would be great
    President:
  • 1,462 Answers
Many bosch dryers are actually white knight. if there is a red reset stat on the back lhs then it is white knight! there is another stat close to the heater but out of sight when you take top off but you can see two grey wires going to it - make a note of where these wires connect, disconnect them and check continuity across them. there is also another stat towards the front. take of the back panel at bottom and you can see this stat in the air duct. check this stat as well. after that you are just left with the heater - check continuity across heater
Posted on Mar 31, 2007
Bosch WTB86200/02 E90 faulted When trying to start The sound of the dryer bips and relay which doesn’t switch
LOTS of fault codes here, but NO "E90"
BOSCH Side by Side Refrigerator Error Fault Codes Error Codes
Then there is this:
"Most of the times when the F:09 Error code apears on a Bosh Dryer is due to the thermal cut off being triggered, you can correct this issue by simply disconnecting the power to the unit and removing the back panel of the machine where you will find the button to be red. simply press it in and test the unit... if this doesn't resolve the issue, most likely your belt snapped off and would need to be replaced."
My Bosch dryer has error code 09 What does that mean
And if THAT is not enough, WATCH THIS!
Bosch Condensing Dryer F09 Error
Anthony
Dec 20, 2017 | Bosch Dryers
Bosch dryer wont heat up
This may help. Notice that the high limit thermostat has a red button.
Bosch Dryer Doesn Heat
Aug 12, 2014 | Dryers
I have a Bosch Nexxt Dryer model #WTMC3300CN/01 & it doesn't throw any heat whatsoever. I have cleaned the sensor filter, cleaned the ducting, & filter but it continues to throw cold air. Could...
Sounds like the heating element. Most dryers have a fin element on the back of the unit. This warms the air as it is drawn past it. If the filter is clogged and not enough air gets to the heater they can burn out very quickly. Also, they can just burn out with age. There is most likely a non resetable overheat stat as well. You can test these with a multimeter (bell test, continuity check) easily. These parts will be easy to purchase and easy to replace with a little diy knowledge
Mar 03, 2018 | Bosch Dryers
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
Bosch Nexxt Electric dryer tumbling but not heating up at all, I here rumors of a reset switch. Where is it located?
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Feb 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
Aug 10, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Feb 24, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
178 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
