Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Is the model 51500 a high definition tv?
I was told by a service repairman that the model 51500 is not a high def' tv. he said it was a digital rear projection tv.
  • 97 Answers
SOURCE: hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Posted on May 01, 2007
  • 395 Answers
SOURCE: QUEStion About Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV>>>>
5 flashes is IK or current to cathode. check the IC's on the crt boards, check the focus block, check the vertcal deflection IC since the IK pulses come from the verticl cicuit.
Posted on Apr 01, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
  • 905 Answers
SOURCE: digital array
that is for adjusting the colors center , you should not use this unless the colors seem off center and then you may make it worse if you do not know what you are doing , this is really for a tech to do adjustments
Posted on Oct 09, 2008
  • 9 Answers
SOURCE: picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Posted on Jan 16, 2009
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
I have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
Its like the tuner is not working
PROBABLY A BAD "HYPERUNIT" FAILURE. IT IS THE DIGITAL SCAN CARD FOR THE TV IT IS WHAT MAKES IT HIGH DEFINITION. IT DOES ALL THE VIDEO AND AUDIO PROCESSING FOR THE TV TRY TO HOOKUP A HIGH DEF SOURCE MAYBE A GOOD DVD PLAYER OR HD CABLE BOX AND IT MAY LOOK BETTER FOR WHILE BUT WILL FAIL ALL TOGETHER SOONER OR LATER.
Dec 17, 2010 | Toshiba 57H82 57" Rear Projection...
It wont work on lower cox channels.. High Def Channels work great
hi, there is an issue with your analog video board, this board converts the lower definition channels to digital, that is why your high def channels are ok
Sep 10, 2010 | Samsung HLP5674W 56" Rear Projection...
Model LG52LG70 has a problem when switching from High Definition channels to non-high definition channels, and vice a versa. The tv simply shuts off, pauses for 10 seconds and then turns on. Time warner...
Any high def TV will momentarily go blank when changing from High Def to normal mode. Ten seconds is an abnormally long time for that to take place. If you still have a warranty on the TV I suggest you take it in to have it serviced. Otherwise you will have to pay to have this item checked out. There are a number of issues that might be causing the problem so it will be necessary to have a technician check it out.
Feb 18, 2010 | LG 52LG70 52 in. LCD HDTV
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Display delay
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Aug 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Toshiba 43H70 - making it HD
you cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Apr 03, 2008 | Toshiba 43H70 43" Rear Projection...
Hd ready?
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
