Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore oven locked after celf cleaning
How do I get my Kenmore oven unlocked after self cleaning mode?  It has been locked since the self cleaning has since ended over 10 hrs ago.  I tried hitting cancel many times and unplugging it for a few minutes I pulled the slide lever to lock when baking to keep my toddler from opening the door. The slide lever was stuck in lock, but was finally able to slide it back to unlock position, but the door was still locked. Kenmore Model 665.4438993 built in 1990.
  • dktshopping Nov 30, 2008
    I pulled the slide lever to lock when baking to keep my toddler from opening the door. The slide lever was stuck in lock, but was finally able to slide it back to unlock position, but the door is still locked. I have a Kenmore microwave on top and oven bottom built into a cabinet. I cannot find any model number other than when I open the microwave and it is Model 665.4438993 built in 1990. The unit has two manual dial for temperature and settings. I tried to go into cleaning mode but neither the lock light or heat light comes on (the heat light come on in bake mode). I turn off the circuit breaker for a few hours and no luck; tried cleaning again after circuit breaker and no luck.
  • 734 Answers
L Press CANCEL to erase the error code.
l Depress and hold down the DOOR LIGHT SWITCH
plunger (located on the front frame of the oven).
l Press CLEAN (not START). Latch will unlock in about 6 seconds
Posted on Nov 30, 2008
  • 4,806 Answers
Be very carefull, the glass on the inside of the door could shatter or might have already shattered.
The only thing you can do at this point in time is disconnect from the mains and leave it of for an hour or so to reset.
seems this is a typical problem when these ovens are set to self cleaning mode
kind regards
    Sergeant:
    Champion:
  • 291 Answers
Set oven as if you are going to self clean and after it goes into its cycle then cancel and it should unlock for you / larry
    Scholar:
  • 126 Answers
Unfortunately unless you are willing to disasemble the stove you will have to have a service technician come out to do the repair.
Posted on Nov 29, 2008
    Sergeant:
  • 291 Answers
Press the cancel button holding it for 5 seconds.after u hear a beep leave it.its unlocked then.
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
My kenmore electric oven was put on to self clean and then immediately turned off but the oven door has remained locked. How do I unlock it?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 14, 2010 | Kenmore 49222 Electric Single Oven
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
heatman101
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
My oven door will not unlock after cleaning
It will take some time for it to unlock. The lock after self cleaning is controlled by temp. The temps during self cleaning are over 900 degrees and after self cleaning it will take several hours before the oven lock will release. Don't try to force. If after 3 hours it has not unlocked you can try disconnecting power for 2 minutes then reconnecting to activate the self cleaning motor assembly. Good luck and thanks for using Fixya
Feb 23, 2010 | Kenmore Ovens
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
Oct 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
178 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
