Question about Sewing Machines
Motor will not continue to run.
Runs only in short spurts. 1 to 2 seconds. belts appear to be ok but seems to be binding up. the motor does not smell.
    Scholar:
  • 41 Answers
Could be any of a number of things:
  1. belts could be worn or stretched and need to be replaced - the belts can look fine but can be stretched causing the machine to run sporadically
  2. if the motor has carbon brushes they may need to be replaced
  3. foot control may have a short or other issue that is causing the short spurts of stitching
You indicate that something is "binding up". What, exactly, do you mean by this? If you mean that the bobbin case does not rotate, the timing of the machine may be off.
A good repair technician can diagnose what's happening and many do not charge (or charge a very minimal fee) to look at and diagnose machine issues. For a small/or no investment you can find out what's wrong and determine if it is worth the cost to fix.
Hope these ideas help.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
New home l373 just started running slower, it still sewing good just not as fast as it was
How long has it been since being thoroughly cleaned and oiled? Usually, older mechanical machines will slow when the oil turns to glue and begins to bind the moving parts. Frequently, you will also notice that the motor appears to be straining to run the machine. If this is the problem, continued use could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Dec 18, 2016 | New Home Sewing Machines
HOW TO FIX SINGER SEWING MACHINE MODEL 223; GREASE WAS USED AND MACHINE IS FROZEN THOUGH MOTOR SEEMS TO BE RUNNING OK
Make sure no thread is caught in shuttle, or around bobbin case, etc. Check "plate teeth" also. Manually turn handle/wheel to engage and slow press pedal.
Is there a burning smell of rubber? Bad motor. Check warranty.
Aug 29, 2013 | Sewing Machines
Baby lock slows down to 0 after sewing a few inches
have you checked
1.to make sure it's plugged into the wall outlet good?
make sure the power & foot pedal are connected correctly to the machine?
2.does the motor smell in any way?
when was the last time it was serviced?
Feb 08, 2012 | Baby Lock Sewing Machines
Machine is powered on. When I press the presserfoot there is no sewing action. The machine emits a soft beep as long as I hold down the presserfoot.
hi, it could be several things
MACHINE DOES NOT RUN
1.the motor belt is probably broken
2.the motor belt may be loose-needs to be serviced
MOTOR DOES NOT RUN
1.the electrical cord may be defective-replace
2.the motor maybe burned out-smell the motor to see if it smells like a dirty pair of socks, if the motor smells it needs to be repalced
3.the foot pedal may be defective-replace
Sep 09, 2011 | Singer Confidence 7463 Computerized Sewing...
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
1967 Bernina 707 Minimatic is not running freely
Have you been oiling the bearings per the guide? Try to isolate the upper mechanism versus the lower by rocking the handwheel and observing which causes the bind (take the bobbin and needle thread off to prevent jamming). You may have to remove some of the covers to see most of it. As long as no gearing becomes shifted or uncoupled, you should not cause trouble. Try taking the motor belt off to see if the motor itself may be binding. Good to see people keeping old, but still working machines running
Oct 24, 2009 | Sewing Machines
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
Mar 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
I just received a baby lock ellegante by UPS yesterday and have try to go by the manual to beginning embroidery. The first thing that pops up on screen is that the safety device has been activiated. I have...
OK here we go:
1. Hopefully the motor belt came off in transit (I have seen this several times), this is easy to fix after you remove the covers. Unfortunately the covers are not easy to remove. But if you can then just put the belt back on.
2. If the hand wheel is stiff then it is a jam or bind. Jams are always in the hook area, binds can be in several different parts which only a technician can help.
I hope it is #1!
Jan 30, 2009 | Baby Lock Ellure
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
