Question about E-Machines eMachines Desktop PC
Connecting moitor yes I am trying to connect a digital monitor to my emachine and it only has a place for connecting a mono monitor. Is there a way I can connect this without to much problem? Thanks so much Steven
    Problem Solver:
  • 16 Answers
If your PC does not support a digital connection you will either have to purchase a new video card or you will have to purchase and adaper from analog to digital.
Posted on Nov 30, 2008
I have emachines w3653 and the no signal keeps popping up
Are you still using the monitor that came with or have you replaced that monitor? The monitor or the cable connecting it to the tower could be faulty. If possible try connecting another cable between the monitor and the tower and then if you still get the no signal message, try another monitor altogether.
Sep 11, 2013 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachine el 1852g-52w motherboard
the problem,maybe the PSU the computer might not get enogh power.or you can allways clear CMOS and se if that helps.
Jun 22, 2013 | Computers & Internet
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I was wondering if i can use any monitor with an Emachine computer? my friends monitor went out and i want to replace it for her.
I use a regular 17 inch monitor from 10 years ago with my eMachine that came with a 22" flat screen. It's just a matter of connecting to the correct input and output. You do have to install the correct drivers for the monitor you are using unless it uses the Windows Generic drivers but it will work.
Feb 15, 2011 | E-Machines eMachines Desktop PC
When turning on the emachine, No Signal shows on the monitor
Please check the cable at the back of the tower connected to the monitor. Make sure its plugged in properly on both ends. If you have another monitor, try connecting that. If still, that does not work, then, check on the video card. If you have a video card, then you should connect your monitor there, and not the internal one. Still doesn't work, try reinstalling the driver for your video card.
Dec 19, 2009 | E-Machines eMachines Desktop PC
E-machine t6540 does not power on monitor
firstly do you have access to another monitor? try this on your pc try your monitor on there pc. you need to find out if it is your moitor or your pc. if it is your monitor replace this. if you find out it is your pc you can buy a cheap pci grafix card this just slots in to any spare pci slot make sure you have a spare the plug your monitor into this
May 16, 2009 | eMachines T6540 PC Desktop
Red has vanished from my monitor
Looks like your video card is having the problem then. Did you connect your monitor to another PC too?
Apr 24, 2009 | E-Machines eMachines Desktop PC
Why does everything that is displayed on my moitor have a blue tint to it?
Could be a problem with the video cable and/or connections. Try disconnecting and reconnecting the monitor cable and move the cable around to see it improves. If this does not change anything it may be an internal issue with the monitor or video card.
Nov 22, 2008 | Gateway Computers & Internet
Two monitors
You just need to get a video with dual monitor support , so that you can connect two monitor on that emachine tower , because basically emachine only came with a video card that you can only connect 1 monitor...
Hope that helps.............
Oct 05, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
