Question about Sony Handycam DCR-DVD105 DVD Camcorder
Unable to play or down disc from my handycam DVD105?
The problem I am having is once I record a disic I am unble to get the dis to play, save or download to my computer.
I am open to any Ideas.
Thank You,
Rudy
    Sergeant:
  • 291 Answers
Recorded disc are suuppose to be finalized or it is also possible that u hve not loaded the software required to play such a disk.
if u recorcing on a dvd cam.install software such as power dvd or vlc player to run it on ur pc.
Posted on Nov 29, 2008
  • 2,427 Answers
Hi you need to finanlize the disc in order for the computer to read it, please have a look at your manual and follow the instructions there to be finalise it. If the disc inst finalised it means there is no sector information where only the camera would read it but not the computer. All you have to do is finalize the disc.
    Genius:
  • 3,422 Answers
Are you facing problem only recorded discs in your PC or all the discs?
  • Priya darshan Nov 29, 2008
    Let me know so that i can suggest you some home remedies.
    Please make sure that you have finalized your disc in order to play it on the PC.
    Genius:
  • 3,422 Answers
Are you facing problems with playing only the recorded discs?Or all the discs in your PC.
Hello, i was charging my video recorder then it felt down, and the cd cover got a little open, once i turn on the camera it said data error, then open and close i tried playing what i had recorded, it took...
Your information should still be there but you have to use a different recorder now that this one is broken or faulty. There should be no problem if you try to use the computer to read the disc. Even if it is the small disc the DVD roms can read them. So try to use the DVD rom and transfer your stuff to the computer hard disc,
Aug 10, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony dcr-dvd105 no sound
Try this:
Play back a recently recorded scene through the viewing screen. Make sure any "mute" setting is turned off and turn the volume up. If you can hear the sound, the problem is not in the camera. Also, run through your menu's audio settings to make sure that they are set correctly.
If you can't hear any sound, repeat the process with an external mike attached. If this gives you sound, the camera's built in mike is defective. Time to hand it in for repair.
If you still can't hear any sound, something else is wrong with the camera. Again, send it in for repair.
Jan 09, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Camcorder disc footage not viewable
try to put it on your dvd rom of computer and see if its working. if you can see the files on your computer, then burn it in nero sofware. so that i will watchable by your dvd player. hope that helps!
CHARCOIS
Oct 02, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Will not finalize
The DVD could be corrupted. Refinalize it and see what happens. Make sure youre using the electrical outlet and not the battery when your doing it.
Jun 22, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony handycam dcr-dvd105
dear tonimo
if you was finish your recording, select menu and choose finalize
it can make your dvd can play in dvd prtable
oke
cropp
Dec 26, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Disc trouble
When i switch on my camcorder, it won't let me record. Error C13-02 is dispalyed on the screen. I have tried 2 different discs and have had no luck. Please help me repairs this.
Dec 22, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
CyberHome DVD Recorder - DVR1600 says No disc when there is a disc
Hi! Pick a jhonson's bud -- dip it into the lens cleaner solution -- rub gently on the lens both clockwise and anticlockwsie -- leave it to dry -- cover up -- run the machine.. but be careful -- don't touch the lens with ur finger and dont try to rub roughly -- lens may go forever. still if the problem remains , replace the lens. chhoton
Aug 21, 2007 | Cyberhome DVD Recorder - DVR1600
Sony Handycam DCR-DVD105 DVD Camcorder Logo
109 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
