I have an 1984 rudd 75,000btu forced hot air unit with pilot light, while cleaning unit an electrical connector broke off ! it looks like a blue plastic wing-nut, and It has 2 large black wires that go to the thermal cut off sensor. I dont know where it connects to???
    Problem Solver:
  • 13 Answers
The simple diagram for that specific problem it connected series to thermal cut off sensor.
The two black wires, One came from a power supply line (it means an active power
and the other one goes to the load motor) If you shorted it connection it will run the motor.
But it bypass the sensor.
Unplug the power then try to fix the both end of that black wire connected to terminal bolt of your thermal sensor by replacing the broken plastic nut with a new one.
Fit the nut thight to avoid electrical arch while giving power on at the start.
r_ic7
Posted on Nov 29, 2008
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Pilot light will not stay light
1) Open following link for how-to resources, illustrations, and service manuals for some brands of heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
2) Many things can cause pilot problems, including bad thermocouple, air in gas line, low gas pressure, negative pressure in house, bad venting, very hot attic, lack of combustion air, dirty combustion parts and dirty pilot tube, bad gas control, reversed polarity on electrical outlet.
3) If pilot flame is clear blue and strong, then next step is check that thermocouple sits in the flame, and then change thermocouple. This is start point. Following step would be reading service manual for exact troubleshoot and testing steps.
4) If pilot flame is yellow-or-orange or weak, then clean dirty combustion parts including pilot tube and air intake. Might want to change thermocouple while combustion parts are removed for cleaning.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
I have a rudd hot air gas furnace,ignitor sparks
to carmelmontgo; do you have a smart gas valve sometimes the wire connections get loose. remove wire connector then reinstall. also cleaning a flame sensor will work if the flame sensor is good. I would check the ground connection sometimes contaminated with rust. also I would check the gas pressure with a gas manometer...my email is alpharomeo@windstream.net
Jan 20, 2010 | Ruud UBHC Air Conditioner
I have Rudd hot air gas furnace. The ignitor sparks and lights the fire but as soon as the ignitor goes off the fire goes out, flame light doesn't go on. What could be the cause?
Hi, Check the flame sensor next to the pilot. It should be a ceramic rod with a metal tip that rests in the pilot flame. It may be dirty. Clean the tip with steel wool real good and make sure it is in the pilot flame good. This will cause that condition to happen. If this doesn't take care of it, get back to me and we will go from there. Should solve you're problem. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Ruud UBHC Air Conditioner
Fails to ignite,sparks but pilot will not ignite. have had problems with pilot going our for about three months. Thought attic air flow was the problem. closed off air vents in area of heater. problem...
Sometimes the pilot orrifice get plugged up and need to be taken apart and cleanned,,,,,, adjust the pilot flame on the gas valve, or check gas going to the unit to see if the in-line gas valve is opening and closing.
Dec 09, 2009 | Ruud Heating & Cooling
I have a goodman central heating . My problem is the electric ignitor will light the burner after a brift time the burner goes out. This problem will go on the entire time of the heating cycle. I have...
Hi!
First of all does this unit uses a hot surface ignitor or a spark ignitor? A hot surface ignitor is a resistive element that will get hot enough(glows yellow to near white) that ignites the main burners directly and a spark ignitor will light a pilot light first then that pilot light will ignite the main burners.
If your system uses the hot surface ignitor then there will be a flame sensor on the last burner that lights. This is a thin silver metal probe that is actually in the burner flame when that burner is lit. It is held in place normally by a 1/4 inch screw. It will have 1 wire attached to the end by a female spade connector. You can pull this wire off before you remove the flame sensor to clean it. Use a fine emery cloth to lightly sand off any residue on it. Also you will need to clean the end of that burner that the flame sensor serves as this is normally the grounding field. This is most likely the problem with your system if it is a hot surface ignition type.
If your system is the spark type then the problem is similar. Normally the pilot light is toughing a small flame sensing probe that is next to the pilot light. This probe also has to be clean. One more thing to look at is to see if the pilot light is large enough to surround the flame sensor. If the pilot is weak it will not touch the flame sensor enough and the system will do what it is doing for you now. If the pilot is weak then the pilot orfice is restricted. This should only be looked at and repaired by a qualified service technician. I hope I pointed you in the right direction!! Good luck!!
Dec 02, 2009 | Heating & Cooling
Rinnai reu-56es. cant get the pilot to light.... testing unit before water lines are permanently connected all filters are clean and wiring seems ok. just exhaust fan wires are not connected . how would i...
To test the thermocouple you will need to heat the tip with a lighter and use fluke meter to test the millivoltage being produced by it. To purge the unit of air shut off the gas line valve. Disconnect the connecter on the unit. And turn on the valve just slightly for a few seconds and release a little bit of gas. Be very careful doing this!!! Make sure there are no sources of ignition nearby. A few seconds of bleeding should be enough to clear out any air in the gas line. Then re-connect and tighten connector using two wrenches(one for a backup) then turn thee valve back on and listen/smell for any gas and soap fittings to check for leaks. After the air is clear if this is a manually set pilot then push the ASO button you use to set the pilot. You may need to hold it for a minute to make sure all the air goes thru the pilot. Then light the pilot while holding the ASO button in. You may need to hold this for a minute or two. When you let go it should stay lit. Look for a strong pilot flame that is blue not yellow and is making proper impingment with the thermocouple/pilot generator head assembly. You will not be able to fully test this unit without the water on due to this unit works off of a pressure/flow switch and the burner will not come on if it does not have water flowing. If it is not electric ignition and the pilot is lit manually then you should be able to light the pilot and have it stay on.
Sep 26, 2009 | Rinnai Heating & Cooling
Relighting the pilot for a rudd heating and air
I dont know of any manufactor that makes a stand alone pilot anymore. (pilot you have to lite). The pilot should lite itself when you turn on the heat.
Sep 24, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
