Computer wont boot - Computers & Internet
  • garethmills8 Nov 30, 2008
    before i did the above i did like the kids do and pressed every key in every combination i could. this gave me options to run diagnostics. An hour later this showed that it wasn,t a hardware problem because everything passed the tests. because i could see light at the end of the tunnel I searched the web and struck lucky!
  • Theresa  Smith
    Theresa Smith May 11, 2010
    Could you give a little more info; like what system do you have, when was the last time you saw (if at all) the comp. working and if you did see it working what exactly were you doing before it shut down?
Dell are brilliant! I eventually found out that dell include a recovery mode in their initial build/set up. This was in microsoft technical articles. Soon after turning the power on press ctrl and f11. This then activates the dell recovery mode even when nothing else will work. On the disc provided by dell when you buy your computer is a program called norton ghost. It was this that allowed windows to boot up properly. I returned the computer to its original settings. I still get a black screen on boot up stating diskette search error and have to use f1 to complete boot up. Microsoft offer a solution to by un checking the related programs on the start up menu by typing various run commands. This might work but I'm not going to do it because my son's computer now works and i'm not risking anything.
Posted on Nov 30, 2008
Computer wont boot up
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Feb 26, 2013 | Toshiba Satellite C850D-BT2N11...
My computer wont boot correctly
won't boot at all?
it's probably the BIOS settings
go to the BIOS settings by pressing F8 or DEL
go to advanced settings
look for "boot device priority" or something like that
set the first priority device as your harddisk
save & exit,restart,happy computing
the "boot device priority" maybe not placed on advanced setting,each BIOS has different interfaces,just look for something like that,it's easy
Aug 22, 2012 | Gateway NV53A24u Laptop
Wont turn on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 11, 2012 | Toshiba Satellite A135-S2276 Notebook
Computer wont boot
so have to check you battery , if battery don't have problem then check your smps............
Nov 19, 2011 | IBM ThinkPad T40 2373 Notebook
Wont boot up
Your hard drive needs replacing. You have lost the boot sector on the hard drive.
Wont boot up completly, keeps re-booting itself
press F8 before the booting screen appears.there u will find option to start the computer in safe mode
Apr 06, 2010 | Computers & Internet
Pc wont boot brings option for safe mode etc k to
Press the F10 key intially when you start , you will get a short cut option in that you select DVD drive option if select that you can boot your system using your boot cd.
Oct 20, 2009 | Mercury Electronics KT266A Motherboard
My Computer Wont Boot Any Kind of Disk
First and foremost, Asus motherboards are garbage, avoid all asus products in the fututre.
You have to set the CD player up as first boot device. If you've done that and it still won't boot from the CD player, the player could have failed or is not connected correctly.
You may have to load software into the bios to start the CD player. Try to find a floppy disk that has CD support files on it. Boot from the floppy to load the CD drivers, and then search the CD for the executable file that you want to run
Sep 20, 2009 | ASUS P4S533-MX Motherboard
Wont boot up at all.
3 Beeps is a Power on self test alert. General this is a card isn't inserted properly or maybe is an AGP card in a PCI slot
Jun 05, 2008 | ASUS M2R32-MVP Motherboard
Boot
have you tried re arranging the boot sequence? try arranging this in bios and at the same time, try cleaning your cd drive.
hope this helps
Jan 27, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
