Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a whirlpool cabrio washer, it is a little over a year old. I believe that the drain line is plugged. Looking at the back and bottom of the tub, (i took the back off) i believe that the tub is full of hair and dirt that won't flush out. I would like to take the center of the tub out to better access the tub it self and clean it out. I got the bolt out that holds the center part of the tub in but can't remove the smaller part of the main tub. Does this come out and is this the best way to clean the tub?
  • 121 Answers
No need to take out the tub you need to check the pump at the bottom tilt the unit over it is in the back where the dran hose is
Posted on Nov 29, 2008
Whirlpool Cabrio Top Laod Model # WED 7800XW I believe the washer ate my shirt. Is it possible that the shirt was sucked down into the tiny space between the agitator and drum in the bottom of...
Thanks for choosing FixYa and welcome to the site. It is very possible that this has happened. It wouldn't go through no drain hose but it can be at the bottom of the tub. Only problem is taking the washer apart tp get to that level.
Apr 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Should we buy a cabrio?
Its recommended to buy whirlpool washing machine they are having the spares for their old model also when compared other brands
May 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My one year old Cabrio top loader stops filling after about 3 min.
check the supply line filter in the back and make sure that it is not clogged
Nov 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine
Check if your belt is tight enough. There should be a "give" of half an inch, or it is too tight or too loose.
Dec 28, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
316 people viewed this question
Dan Webster
Dan Webster
Sal De
