Question about GE Spectra JBP78 Electric Kitchen Range
Front door glass panel
I need to clean it inside , I don't know how to remove it
  • Anonymous Dec 06, 2008
    I took the entire door off and now need to put it back on. How do I line it up and put it back on the front of the oven
    Habit-Forming:
  • 171 Answers
Lift the door straight up, it will come out then take the screws arown the edge, and if the door handle screws go acros the door remove does to.
Posted on Dec 06, 2008
3 Suggested Answers
  • 219 Answers
SOURCE: Glass Door stain
you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
Posted on Mar 25, 2009
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
Take the front glass panel off my range to clean between the glass
This should be a double paned insulated glass, you will need to take the door apart to get behind the glass.
Jan 27, 2015 | Maytag Precision Cooking System Electric...
2012 GRAND CHEROKEE REMOVE DOOR GLASS
how to ? You or them? who is doing this? DIY?
front or rear. left or right.
the fsm covers this.
or for 15 bucks alldata.com? RTM?
wk jeep
qoute
1. Remove the outside rearview mirror (Refer to 23 -
BODY/EXTERIOR/OUTSIDE REARVIEW MIRROR
- REMOVAL).
2. Remove the front door glass (Refer to 23 - BODY/
DOOR - FRONT/DOOR GLASS - REMOVAL). below....
3. Remove the weatherstrip from the front glass run
channel.
4. Remove the nut (2) that secures the top of the
front glass run channel (1) to the inside door panel.
5. Loosen the nut (3) that secures the bottom of the
run channel to the keyed hole on the inside door
panel.
6. Lift the front glass run channel upward within the
door far enough to disengage the nut that secures
the bottom of the run channel to the keyed hole on
7. Remove the front glass run channel from the door.
(back in is longer story) FSM C23 pg 16
and 23page
1. Remove the outer belt weatherstrip (1) from the
front door.
2. Remove the trim panel from the inside of the front
door (Refer to 23 - BODY/DOOR - FRONT/TRIM
PANEL - REMOVAL).
3. Remove the speaker from the inside of the front
door (Refer to 8 - ELECTRICAL/AUDIO/SPEAKER
- REMOVAL).
4. Remove the watershield from the inside of the front
door (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD
- REMOVAL).
5. Using the regulator (4), move the front door glass
(2) up or down as required to access the two window
regulator glass clamp bolts (3).
6. Loosen the bolt in each of the window regulator
glass clamps far enough to release the door glass
from the clamps.
7. Disengage the door glass from the window regulator
glass clamps.
8. Lower the regulator down as required for access to remove the door glass.
9. Carefully rotate the door glass within the window opening and remove the glass from the door through the window
opening.
sorry tool lazy for photos today....
Jul 17, 2012 | 2012 Jeep Grand Cherokee
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Fallen driver's side window
probably need a new window regulator. ebay. 93 to 98 should fit.
Section 01-05: Trim, Interior 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. swv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942) .
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel .
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screws from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124) .
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure.
Window Regulator, Power Front Door
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Remove the front door window glass (21410) . Refer to the front door window glass removal procedure in this section.
  1. Remove the two front door brace bolts and the front door brace.
  1. Disconnect the front window regulator electric drive electrical connector.
  1. Remove the four front door window glass regulator track bolts.
  1. Remove the three front window regulator electric drive bolts.
  1. Remove the front door window glass regulator track and the front window regulator electric drive (23394) as an assembly through the opening in the front door (20124) .
Installation
  1. Install the front door window glass regulator track and the front window regulator electric drive as an assembly through the opening in the front door .
  1. Install the three front window regulator electric drive bolts. Tighten the front window regulator electric drive bolts securely.
  1. Install the four front door window glass regulator track bolts. Tighten the front door window glass regulator track bolts securely.
Apr 29, 2009 | 1998 Mercury Villager
Power window problem. engauges then disenguages
Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
  1. Remove inside door belt weatherstrip.
  1. Remove front door window glass (21410) as described in this section.
  1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
  1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
  1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
  1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
  1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
    Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Installation
NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
  1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
  1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
    Install four rivets to retain front door window regulator to door inner panel.
  1. Install window regulator equalizer arm bracket.
  1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
  1. Install inside door belt weatherstrip.
  1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
  1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
Apr 13, 2009 | 1997 Ford Windstar
Stove
We cleaned the inside of our glass door today, it was easy but unfortunately we had a problem. Hopefully this will help you avoid the problem we had which shattered the outside glass on the door.
1) Open the door all the way, but put some support under the door to prevent it from dropping. It helps if you have someone else support the 2 halves of the door.
2) There are 2 screws on the top inside of the door. Carefully loosen both screws. This will detach the front of the door from the back and allow you to clean it. BUT, this is important: Do not allow the inside of the door the swing back toward the closed position as this will cause the glass to shatter.
3) Open the 2 halves of the door only enough to get your hand in and clean the glass. Avoid moving the doors while cleaning and avoid excessive pressure on the clean when cleaning.
4) Once you finished the cleaning carefully place the doors back together and tighten the screws.
Apr 30, 2008 | Kitchen Ranges
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
127 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
