Question about Mitsubishi WS-65713 65" Rear Projection HDTV
TV not turning on
We can't seem to get beyond the blinking green light to get the TV to turn on. I had a repairman here and he indicated that there were two boards and they were not talking to each other. He removed one of them for 24 - 48 hours and put it back in the TV and still we only get as far as the blinking green light. I need to order a new part, but i am not sure what it is. I live in a remote area, and i have not been able to get the repairman to respond. Help, is it possible to figure out which board i need and is it something i can install myself?
  • 4 more comments
  • 925florist Nov 28, 2007
    I can't get beyond the blinking green light to get the TV to turn on. I have tried holding the reset button for over a minute, I have turned the power off. I'm ready to call a repairman. Same quesion, can fix it myself or do I need a repairman?
  • mahfactor Dec 02, 2007
    I'm having the same problem with my TV. It just happen this AM. Ken
  • Anonymous Dec 05, 2007
    Timer Button Blinking - Can't Turn Mitsubishi WS 67713 on.
  • roger_lee_98 Jun 23, 2008
    I am having the same issue. I just received this TV from a friend and after plugging it in can't get past the blinking green light on the front. It wont go off and the tv wont turn on from either the remote or the control panel. I keep reading about check the 4 capacitors but Im not sure where the DM module is located and how to test these capacitors. If someone could help me out with this, I would appreciate it as I live out in the middle of nowhere and don't have a certified Mitsubishi repair man available.
    Thanks,
    Roger
  • sweetbean Jul 17, 2008
    tv turns its self off after I turn it on. Is there an inexpensive solution?
  • Anonymous Sep 09, 2008
    blinking green light is all i got. the tv will not turn on but i get sound through my system but the tv will not turn on. my sound is through a different system and there is a cable box, dvd player and sound system all connected and everything else works just not the tv. any ideas?
You need to call Mitsubishi about this as I have the same problem and have been WAITING SINCE AUGUST, 2007 for a replacement board. Mits has had this board on backorder since July, 2007. Seems that they can't get them in from Japan, they constantly change the ETA of the board, and then they (Mits) say they will expediate but that takes about 1 1/2 weeks to do that. Their number is 1-800-332-2119 and press 5 to get to customer relations and THEN you WAIT, and tell Mits what is going on and then they put you on hold AGAIN and they transfer you to a HIGHER LEVEL, only to have to repeat the same story AGAIN!! Each time you wait, the time frame gets longer and longer but stick with it. If a repairman comes to your house, the repair is going to work about 3 months and the board goes out again. Now Mits wants me to find all receipts so that they can issue store credit (purchased thru Good Guys, who is out of business!) I purchased my MIts w-61573, Jan 2004 and OF course, I am unable to find receipt for big screen, locating only the repair bill so far. I may be up the creek without a paddle. I sincerely hope Mits comes thru. I hope you can use this info. Good Luck
Posted on Dec 28, 2007
    Genius:
  • 1,694 Answers
Four bad capacitors in DM module = common repair for a
qualified Mits repairman.....1000mf/25v 105 degree............T.
Posted on Nov 22, 2007
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Model WS 73713, mitsibushi big screen TV. green blinking light on front panel doesn't stop blinking and tv will not turn on by remote or power button on panel
called a TV repairman. I know $65. to start service call but feel it will be fixed correctly in a timely manner.
Sep 08, 2008 | Televison & Video
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Jan 08, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WS-65713 65" Rear Projection HDTV Logo
279 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
