Question about Samsung Spinpoint MP0402H 40 GB Hard Drive
The request could not be performance cause of an i/o device error
I have issue on my portable HD. When I connect to my usb port, drive already appear at windows explorer but when I access to that drive system have error "the request could not be performance cause of an i/o device error".
How can solve this issue ?
  • apdies Jan 11, 2009
5 Suggested Answers
lock123
  • 6831 Answers
SOURCE: Portable External Hard Disk - Not Recognized in Explorer
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
albert_price
  • 190 Answers
SOURCE: after i connected my Samsung portable hard drive,
Click Start, Run and enter DISKMGMT.MSC Locate the drive in question and
ensure that its assigned a drive letter. If not, you'll need to manually
assign a letter to it.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart
Display\Security
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
If that fails. try the solution using the following link.
http://www.physiology.wisc.edu/comp/blog/2007/bb20070425_01.asp
Hope this helps you.
Any further questions feel free to ask.
Posted on Nov 23, 2010
  • 72 Answers
SOURCE: I have just bought a
head over to samsung's download page: http://www.samsung.com/us/support/downloads Pick out your model and download the diagnostic software. I think it's called something like Diagnostic Software for portable HDD.
Posted on Mar 21, 2011
SOURCE: Samsung S2 Portable no longer detected
same problem here, started happening just yesterday and now it's just flashing and is never detected.. I've tried emailing the Samsung support, will tell you if I receive any useful answer (as proposed by the very helpful person at http://www.fixya.com/support/t8050821-dear_fixya_trouble )
Posted on Oct 11, 2011
My external hard disk cant initialized
Try it on the rear ports on your motherboard if it is usb. Make sure the cable is a good onem try exchanging for another. For a device th intioalise drivers should be necessary, does it come with any, which operating system are you using. Have you tested it on another computer to check that it is functioning? There are lots of things to check
Also, before you do anything else, ensure that all usb support is enabled in bios.
Jun 10, 2015 | Western Digital 1TB My Passport Essential...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
No cpu will recognize the drive or acknowledge it is connected to the cpu. This problem occurs across all the ports (firewire and usb). The drive lights up and receives power from the cpu and hums and...
make sure that you plugged in the Portable HD to a USB 2.0 port. delete the USB root hub from your device manager and install it again. change your data cable.
Mar 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Wd250
try formatting it again using your pc.and if it has a bundled software try to install it, maybe it works, although portable hd dont need a software at all.
Sep 27, 2009 | Electronics - Others
I have a Acom data hard drive Model HD500uhe5-72
Here's what you need to do:
1. Try connecting the HD (hard drive) into different USB ports of the computer.
2. Try another computer to see if the HD would be detected.
3. Try another USB cable.
Do you hear a clicking sound on the HD itself while it's turned on? Check the Disk Management of your Vista computer to see if the HD would be detected under the Disk Management. Please follow the steps below:
1. On your Desktop screen, right-click the "Computer" icon > select "Manage".
2. Double-click on "Disk Management"
3. Connect the HD while looking at the Disk Management. If the drive letter appear then, it's your Acomdata HD.
4. Check the status if it's healthy or unallocated disk space. If it appeared to be unallocated, you need to reformat the HD to make it work again.
To reformat it, just right-click on the drive letter that would appear and there's an option to reformat.
NOTE: Formatting a HD would erase all the data saved in it.
Have a great day!
Sep 21, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | Toshiba 120GB USB 2.0 Portable External...
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Samsung Spinpoint MP0402H 40 GB Hard Drive Logo
21 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
