Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice dispenser doe not work
Water dispenser works, ice maker works. When I push the crushed or cubed buttons the green light over each individually comes on, then I put a empty glass in compartment to catch ice and push in the lever I get nothing, no auger movement ,no noise.....nothing ,except the green light over the cubed or crushed goes off for about a second then comes back on while I am holding the lever in.
  • GE Master
  • 19,396 Answers
If you do not get any water at all , then it is likey that water lines to the ice maker are clogged or water is iced inside, check it out.
Posted on Nov 29, 2008
  • 849 Answers
SEEMS POWER SUPPLY PROBLEM.
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
