Question about Canon imageRUNNER 2000 Copier
CANON IR 2000
Hi - just a quick question. I have a number of double sided A4 sheets that i need to photocopy. I need the copies reflect the original i.e. to be double sided also. Any ideas how i find this setting on the Canon IR2000, thanks very much.
  • Anonymous Nov 16, 2007
    How to select double sided copying
  • 62 Answers
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Posted on Sep 05, 2007
My canon ir 3320i copier toner is leaking from drum unit fix it
Can u plz Check Cleaning Blade and Mylar sheet for cut,
Check Charge Roller if gone bad.
if both seems to be ok, then change Drum Unit .
Aug 13, 2017 | Canon Office Equipment & Supplies
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Can the Canon Imagerunner 3030 count/sort sheets of paper out for you?
please, the count you want is copies made or you want the machine count the originals ??
The machine count 1 copie for A4 (LGL) and 2 copies for A3, called double count.
Nov 20, 2009 | Canon Office Equipment & Supplies
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
How to make automatic duble sided copy on IR-2000
these machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
May 31, 2009 | Canon imageRUNNER 5570 Copier
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
IR 5000-6000 LGL TO A4 PROBLEM
What country are you from ???? here in the US we do not use A4.
Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
Oct 11, 2008 | Office Equipment & Supplies
Canon imageRUNNER 2000 Copier Logo
395 people viewed this question
old marine
old marine
