Question about GE Refrigerators
Freezer temp is rising to 12 degrees and doesn't reset
GE Profile Refrigerator, PFS22MIWAWW. Temp has risen to 12 degrees. tried to reset with controls inside refrig, shows -1 degree ,but cooling doesn't kick in
  • 1 more comment
  • Anonymous Mar 25, 2014
    my GE Profile, pfss6pkw, refrigerator control buttons are going crazy changing temps,beeping that it is changing and turbo cool going on and off what can it be the control unit or just sensor pins"
  • Anonymous Mar 31, 2014
    I have a GE Profile Refrigerator model PSCS5GX and the refrigerator part was fairly warm today. I went to reset the temp. to 37 degrees as it was at 33 when I pressed reset. However, it went up to 34 and stayed there ...could not get it any higher as recommended on the front of refrig. then it started beeping and asking to reset...but how?
    Sandy
  • 33 Answers
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer temp risen to over 50 degrees. Refrigerator temp also risen to over 50 degrees. Water puddle on floor.
Check the fan in freezer is it running? Check the fan by the compressor is it running? Is the compressor actually running? Be careful can be extremely hot.
Nov 13, 2009 | Refrigerators
Freezer frost then loss of cooling
There is a block of ice that is causing the air to not flow across the coils as it should. This is why the temp has risen. You can do a manual defrost by un-plugging the unit over night but I would call out a ref tech to check the defrost timer and the freon level. Hope this helps. Good luck. Please re-post with updates. Thanks cj2176.
Jul 13, 2009 | Fisher and Paykel Active Smart E522B...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Ge profile french door bottom freezer the freezer temp has been fluctuating form 4 t0 14 degrees have been using turbo cool control to reset drops the temp but by the end of the day its back up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 28, 2009 | GE Profile PFS22MS Bottom Freezer French...
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Refrigerators Logo
470 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
