Question about Zanussi TC7102W Electric Dryer
Not blowing hot air anymore
After cleaning all fluff filters my unit will no longer produce hot air. My husband has replaced the heater element but still no heat. Any ideas would be really appreciated thanks
    Problem Solver:
  • 9 Answers
There are two thermostats..one above and one below the heating element..they probably need to be replaced..about 30 bucks canadian..have the shop check your heating element for resistance I had the same problem with my Whirlpool, when I called around for prices one shop suggested the thermostats and then tested my element for conductivity. When it passed he sold me the thermostat replacements(they are sold in pairs) They were very easy to install, just make sure the wires are on correct..Check for small marks beside the leads and then match them up while removing old and installing new. I hope this helps
Posted on Apr 11, 2007
SOURCE:
Dv210aew/xaa THERMAL FUSE keeps blowing after replaced 3 times. Cleaned out exhaust and replace heater element and thermostat switch, what else can it be the problem?
on the blower housing there's a thermistor that takes the place of the cycling t-stat,if that's not working correctly the dryer will run to hot or not hot enough,also check the duct that the lint filter slides down into,make sure that isn't clogged with lint,then run the dryer with the vent line disconnected to make sure there isn't anything blocking it,how long is the vent line?if it's a long run i stick a leaf blower into it and blow the stuff to the outside,you should take the dryer apart and clean it at least once a year and blow out the vent line so things like this don't happen,part number for thermistor is DC32-00007A.what thermal fuse are you changing there's one on the heater box and one on the blower wheel housing if it's the one on the blower wheel housing you could still have a block in the vent line or a thermistor problem,if it's the one on the heater box you could have a bad high limit that's the t-stat next to the thermal cutoff on the box,one more thing when you changed the element did you buy the whole part with the t-stats,if not if you ever have a problem with the element buy the whole thing you get the element and t-stats together and you just pull the wires off and change the whole heater.if the vent isn't clogged and you changed all the t-stats and it still pops you could have a bad computer board,do this,when you change the thermal fuse,start it with the vent line disconnected,put it on air fluff and start it,if the heater comes on the element is shorted one of the coils are touching metal,if the heater doesn't come on run it with the vent line still disconnected and see what happens,those t-stats are pretty reliable but one could be bad but the board could be the problem but the dryer is running to hot and popping the thermal fuse,use a watch to time it,when it starts with no clothes the heater should stay on for no more than 3 to 4 minutes,then it should shut down,for a minute to a minute and a half and come on again but now it should only stay on for like 50 to 60 seconds and shut down.sorry to make this answer so long but without being there i'm just trying to tell you what i would check.let me know what you find,keep an eye on how long the heater is staying on if you think it's on for to long while you're checking it stop it and put it on air fluff to cool it down so you don't cook the thermal fuse again
Oct 07, 2017 | Dryers
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
My LG Tromm electric dryer won't heat - again.
if the high limit is popping the dryer is getting to hot,i know you say you checked the vent line but i've heard that before,when i get out i remove the vent from the back of dryer,change out the t-stat and run it with the vent line off and it runs fine,how long is the vent line?if it's a long run remove it from the back of dryer and stick a leaf blower into it,blow it out to the outside and see what comes out,also first run it on air fluff,if this is a newer dryer set it to timed dry and then you can set it to air fluff,go outside and feel how it blows,then after you blow it out check it again,if you see alot of lint blow out and it's blowing harder your all set,you should take the dryer apart and clean it and the vent line once a year and you won't have any problems like this,also you won't have to worry about a dryer fire,your clothes will dry on time and less parts will have to be changed out,also when you get it to heat again run it on air fluff,if it gets hot on air fluff you have a shorted heater,one of the coils are touching the metal box on the heater and the heater won't shut off,also you have to clean out the duct where the lint filter slides down into,if this is blocked the dryer can't push the air out the blower wheel is blocked with lint.hope this helps you out happy holidays
Dec 25, 2017 | LG Tromm Electric Dryer
Dry run hot for awhile and next time I use it it blows cold air.
Hi, this could be because your fluff filter needs cleaning out or there is a blockage in the air exhast causing the machine to overheat and the thermostat to cut out until everything cools down, if that isn't the problem then perhaps suspect a faulty time switch or bad connections on the heating element.
hope this helps
Feb 13, 2011 | Kenmore Dryers
Dryer does not get completely hot. Kenmore 110
most likely this is due to a build up of fluff in your filter, when this happens air can not escape and youl find your washing to be warm but still wet and far from dry.
Sugest you clean your filter, any problems feel free to get back to me
Feb 12, 2010 | Kenmore Dryers
Dell inspiron is turning off randomly
Sounds like overheating, daughter had same problem. Don't blow air thro cooling element on the back of the laptop, you'll blow any accumulated dust/fluff back into the fan, which will just blow back into the cooling element when the fan switches on or it'll stop the fan from rotating altogether. First turn it over and take the battery out, then remove the big L shaped cover from the bottom. There's a thick copper conductor leading to the cooling element' GENTLY lift the cooling element clear of the laptop base, using a soft brush remove any dust/fluff from the element. Then using canned air blow from the bottom of the laptop thro the fan to clear any dust/fluff. Once cleaned GENTLY push the cooling element into position and replace L shaped cover, replace battery and away you go. Daughters has been OK for a few weeks now, amazing how much fluff collects in those fans.
Hope this works! Gaz P
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Heater wont blow hot air anymore.
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Dec 01, 2008 | Holmes Products HFH111TU Compact Heater
The dryer is not getting hot anymore
Three things usually contribute to this:
The air (lint) filter not clean of fluff. (Is the air still blowing strong from the air vent (front or rear)?)
A faulty heating element.
A faulty thermostat
Sep 16, 2008 | Dryers
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Zanussi TC7102W Electric Dryer Logo
486 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
