i have a minn kota 70 lbs.thrust, 24 volts, it will only run on #10 high speed, when i turn down the...
(More)
I HAVE A MINN KOTA 70 LBS.THRUST, 24 VOLTS, IT WILL ONLY RUN ON #10 HIGH SPEED, WHEN I TURN DOWN THE SPEED, NO CHANGE
Got fishing line bound up on prop and stopped the motor. I had to remove prop to get the line out of...
(More)
Got fishing line bound up on prop and stopped the motor. I had to remove prop to get the line out of the prop and motor housing. Now when I press the run button on the remote a click in the electric housing that feeds the motor is all that happens and the motor won't turn. I haven't taken that housing apart yet, is there a relay that may have burned out when the line bound up the motor, is there a reset or fuse that may have burned out in that housing?
I have a Minn Kota Maxxum 70 and the depth collar slips. I hear there is an upgrade for this. Any...
(More)
I have a Minn Kota Maxxum 70 and the depth collar slips. I hear there is an upgrade for this. Any idea where to purchase and part no.?
Hi. it seems the bearings on my min-kota shaft are damaged. how do i dismantle the shaft?? advice...
(More)
Hi. it seems the bearings on my min-kota shaft are damaged. how do i dismantle the shaft?? advice would be great. thanks
