Question about Refrigerators
I have a kenmore 106.52603100 side by side refridgerator. A few days ago we found water in front of the unit on the floor, it appeared to have come from the ice maker and it is now not working, no water is going to the icemaker at all, the water dispensor on the door is ok and the freezer is cold enough for ice. What do you think is wrong or what can I do to trouble shoot the problem
  • 1 more comment
  • anclacour5 Nov 29, 2008
    Not sure how to check the ice maker it self as far as its arm setting, it doesn't have an arm like most of the others I have seen.
    But when I tested the solenoids with an ohm meter one is closed and the other has resistance, if that's what you were referring to, then yes the problem is the solenoid, correct?
  • anclacour5 Nov 30, 2008
    Replacing the water valve worked! Thank You very much!
  • urbabyonly May 11, 2010
    Whirlpool gold fridge side by side not getting very cold, freezer is fine. cleaned ils, etc, where is the timer?
  • 33 Answers
First thing to check is if the water inlet tube is blocked with ice or not. Often this is the case and people have their icemakers replaced with no luck. It the tube is not frozen with ice, then check the arm that turns your icemaker on and off. this should be in the down position. There may be a reset button on the front of the icemaker.
There is one solenoid that control water to the icemaker and a different one that supplies water to the dispenser. Often the Ice solenoid will quit. If you are good with an electronics meter, you can test the resistance across each solenoid....they should each measure the same. If one reads open or much less then the water supply valve is bad.
Posted on Nov 29, 2008
  • Larry Foster Nov 30, 2008
    You can swap the plug on the solenoid , go to the front and push the water dispenser lever, if your icemaker tray fills with water then you have a bad solenoid. The whole water supply valve needs replaced as a unit.
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Refridgerator will not cool. Freezer works fine. Noticed a pool of water on floor then started to cool again. after a few days quit cooling.
Check the water drain hole in bottom of unit. If plugged water cannot get to catch and pan and evaporate with the heating element.
Aug 25, 2011 | Maytag MZD2766GES Side by Side...
We have Kenmore/Coldspot side by side model 106.44259401 Over the last few days the freezer has 'blizzard' conditons. Frost accumulating on top /sides/packages. Also appears the refridgerator side...
Sounds to me like your defrost heating element is shot. Unplug the refrigerator. Empty out the freezer take the screws off the back panel and remove panel. Defrost the cooling coils with a hair dryer. At the bottom behind the shield you will see a glass tube. Unplug it and bring it to your local app repair shop and let them match it up because making the phone call with your make and model doesnt always work but bring those numbers with you as well.There was some models made with single heating elements that had to work twice as hard to get the defrost job done so they burned out more often. Your repair store will probably have a new dual tube for ya. Hope this helps. Almost forgot..Make a temporary plug with a paper towel and stick it in the water drain just in case you drop a panel screw down the drain(not fun) good luck!
Jun 26, 2011 | Kenmore Side by Side Refrigerator
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
REFRIDGERATOR LEAKING WATER ON THE FLOOR
HI. This may be a drain pan issue.
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Jun 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Refrigerators Logo
389 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
