Question about Canon PowerShot A710 IS Digital Camera
Memory card error message
When I put a memory card in the PowerShot A710 IS camera I get a memory card error message. The cards work in other cameras but not this one.
  • 138 Answers
Try to reformat that card via a card reader/writer.. then reformat it using the camera thru the menus.
Posted on Nov 29, 2008
Card locked error
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 17, 2013 | Canon PowerShot A710 IS Digital Camera
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Hi, my canon powershot A710 IS says CARD LOCKED. how do I unlock it?
SD memory cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Oct 31, 2010 | Canon PowerShot A710 IS Digital Camera
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
PC transfers files to and from SD memory card but camera show "No image" on SD card. Why can the camera no longer recognise picture files?
If you are putting pictures on the card using the computer and then expecting to see them on your camera, it doesn't work that way. You also run the risk of corrupting the card and even the camera.
Dec 02, 2009 | Canon PowerShot A710 IS Digital Camera
Card Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Sep 06, 2009 | Canon PowerShot A710 IS Digital Camera
Lens error, restart camera.
I had the same problem with my powershot and with the batteries going bad super fast. The way to fix it is to empty your memory card of all pictures then put it back in the camera blank. That should take care of the problem and should pro;long your battery life as well.
Aug 25, 2009 | Canon PowerShot A710 IS Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
270 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
