Question about Samsung SGH-G600 Cellular Phone
Will not connect with the pc, just charges instead.
I have looked at other troubleshootings or similar problems and tried there answers but nothing has worked so far.
When i connect my phone the the pc it will just charge and not connect to the software i have installed.
  • 13Debbie Dec 05, 2008
    I have the same problem. My PC says the software has correctly been installed & that I am connected but when I plug the usb cable in it just looks like it is charging and nothing happens. The usb cable came with the phone and has never been used so is brand new.
  • Anonymous Dec 08, 2008
    it let me install the USB cable but won't let me install the PC studio. Just says refer to user's guide but there is nothing in there to help
    President:
  • 2,110 Answers
I think some problem in ur data cable ..try to use another cable...
Posted on Nov 29, 2008
Hi my kubik after 1 week will not switch on or charge or do anything once plugged in to pc. can i reset it?
In answer to your question, no not in the sense that you mean (similar thing happened to mine). If it does not work at all (that is to say cannot be burned on) when not connected to the PC then I'd say that it needs returning and repacing. If it does switch on when not connected to the PC then try another cable justin case this is the fault, though I am more inclined to the "back to seller" route as the most probable outcome.
Mar 14, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
My player charges but does nothing else
Try a different USB cable instead. Most likely a pin in the USB cable your are using is faulty and because of that your computer can't detect your player as the pin required for your computer to detect it is faulty. You can take a look at http://mympx.org for other users who have similar problems as well.
Jul 14, 2009 | Sony NWZ-A816 Digital Media Player
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Walkman will not power up or charge.
I just solved a similar problem with my Walkman. When I'd plug it into my computer, it wouldn't charge. I read in the troubleshooting section of the manual that it could be a problem with the computer or its USB connection. I connected my mp3 player to a different computer and it charged fine. If it's not responding at all, you may want to try the reset button (if your model has it).
Hope that helps!
Apr 15, 2009 | Sony Walkman NWZ-B135 MP3 Player
Mio 168 not charging when using Car Charger
You have to have an ignition switch on, only then to connect a device. It is to protect device against an electric shock.
firo
Dec 15, 2008 | Mitac Mio 168 Pocket PC
Samsung YP-Z5F
I've had various issues similar to those described, and can offer the following trouble-shooting and/or work-around tricks that I've had success with:
Sometimes, when I come to use it I find that it won't turn on at all, but it's most likely because it's been a while (several weeks) since the last time that I used it.  The battery does seem to lose its charge over this time.  All I do is to charge it up for several hours, (or even overnight).  It usually charges best by leaving the unit OFF when plugging in the USB cable to the PC, just like a cell phone does.
As for the problem with the PC recognizing it, sometimes it just takes a few minutes. I have winXP.
First, open MyComputer.  If the mp3 player doesn't show up as another drive after about 60 seconds, press the F5 key to 'refresh'.  Sometimes closing MyComputer, then re-opening it makes a difference, too.  You might also want to try a different USB connection, like using one in the back of the PC instead of the front (or vice-versa).
Sometimes, though, it doesn't hurt to just press the RESET button at the bottom side (6 o'clock position when holding it upright and facing you).  With it turned ON, I insert a paper clip that's been partially straightened out, holding it in for about 3 seconds.
Jul 30, 2008 | Samsung YP-Z5FA MP3 Player
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
My Garmin Nuvi 250w
how can i get updates downloaded onto my garmin nuvi 200 series,i have it connected to pc but nothing is downloading,new roads,places,construction ect.
Mar 26, 2008 | Garmin nuvi 200W GPS Receiver
Samsung SGH-G600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
