Question about Micrografx Designer 9 Full Version for PC
I'm running Designer 9 with Windows Server 2003 and want to import a DWG file, but when I tried it said "DESIGNER WAS UNABLE TO TRANSLATE THE DRAWING:"
"Could not translate file 09-067DETAILS.dwg. Either a translator for this file is not installed, or files of this type are not supported."
  • Dustin Olson Jun 08, 2012
    I am going to re-install the software.
4 Suggested Answers
  • 10406 Answers
SOURCE: I am getting an error
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Posted on Jan 27, 2011
taran_2005
  • 10515 Answers
SOURCE: I have been using Micrografx Designer 3.1 in
The present Graphics DLLs are compatible with Designer 3.1 with
OLE (dated May 28, 1992). If you are running an older version of
Designer on the OWS and the drawing uses Designer fonts, displaying
the drawing would give a protect violation from DCP by
MGXLIB.DLL because the MGXFNT.DLL are not compatible.
You can replace the older version of the MGXFNT.DLL with a new
one. To do this, copy MGXFNT.JCI from the C:\FMS\BIN
directory to designer libraries directory (MGXLIBS) and change the
file extension to DLL (i.e., MGXFNT.DLL). By default, the MGXLIBS
directory is located under C:\WINDOWS; however, you should copy
the file in the same directory that is pointed to by the Libraries
parameter in the Micrografx section of the WIN.INI
(e.g., Libraries=C:\WINDOWS\MGXLIBS
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 25, 2011
muntejaya
  • 10421 Answers
SOURCE: how i can import picks.. when i try,i got only
Please re install the software then.
Regards, jay
Posted on Feb 26, 2011
Label created with Zebra Bar One V5 read in Zebra Designer
Hi Jonathan. Did you ever reach a solution? We are in same baot with over 60 Barone v5 formats to convert to SAP. Thanks in advance. Mike
Jul 04, 2012 | Zebra DESIGNER FOR MySAP BUSINESS SUITE V2
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
I have TurboCAD Designer 2D for Mac V.5 December. Last night I opened my old project, made some changes and saved it. Now when I try to open that revised file I saved last night, I get error message:...
Hello!
If autosaved is enabled in your CAD, then most likely you can recover a n sv$ file of it saved in a temp folders. You can rename this file and change the extension from .sv$ to .dwg.
This link may help you find the folder where autosaved CAD file is stored
This link might help you also.
Good Luck!
May 03, 2011 | IMSI TurboCAD Mac Designer 2D 5
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i...
Close Designer 9.
Jan 27, 2011 | Micrografx Designer 9 Full Version for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
I have a Zebra S4M printer and it has always printed fine. I downloaded Zebradesigner software to be able to create a label, but i am having trouble setting up the printer through the Zebra Designer...
you need to load the zdesigner driver from the zebra website, the older zebra universial wont work with zebra designer that why you can't pick it.
http://www.zebra.com/id/products/global/en/drivers/barcode/zd_driver_1_4_52.DriverFile.File.tmp/ZD1510Certified.exe?dvar1=Drivers&dvar2=Zebra Designer Driver (32 bit/64 bit, Windows Certified) &dvar3=50
Cut and paste the whole link and paste into the address bar of your web browser or just goto zebra.com and click drivers and downloads.
Jul 08, 2009 | Zebra Designer Pro for PC
I use frontpage 2003 to edit my site( http://www.riversoftime.com) I am getting an error message on my page called ''Miscellanous'' that reads: An error has occurred accessing windows share point server...
Hi..seems you are trying to edit SharePoint Portal sites using frontpage...open the same using sharepoint designer and with proper administrator credentials..(usually it prompts when you connect to server using a client machine)...All changes done to the application files are then committed on the server- end and will work absolutey fine../
warm regards.
May 06, 2009 | Computers & Internet
Transfer diamond Monogram program to floppy disk
Put the floppy disk in your computer and look at the files that are on the disk using windows explorer. If the names have common file extensions such as .hus, .vip, .vp3, .pes or the like, the files are in the wrong format for the machine to read. For the Designer 1, you must have them in .shv format. The floppy should contain 4 menu files and a couple of extras that you won't know about but they are still important for the machine to read the disk.
May 29, 2008 | Husqvarna Designer I
Importing TIF files in Adobe Designer
than change you resolution DPI
as you increase your DPI you will get batter quility but haveing quit more size than previous tif,
so try & funn,
THNX
May 16, 2008 | Adobe Photoshop 7.0 for PC
Micrografx Designer 9 Full Version for PC Logo
105 people viewed this question
Top Micrografx Computers & Internet Experts
David Payne
David Payne
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
