Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
No heat my HE3 dryer is not producing any heat could there be a simple soluntion?
  • 116 Answers
REMOVE THE BOTTOM PANEL SHOULD BE 2 SCREWS HOLDING INSPECT IGNITOR IF HAS SMALL BURN MARK REPL,, IF NOT THEN REPL, THERMAL FUSE THAT WILL FIX THAT
Posted on Nov 30, 2008
Wont produce heat
U need to check the device responsible for generating heat - if electric it is the heating element(s) - if gas make sure the pilot is lit and there is gas going to the unit.
Aug 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
Apr 30, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
He3 8519320a dryer dosnot heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jun 13, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
My Gas Dryer has stopped heating. I've checked the breakers and reset them...if the thermal fuse is bad, will the drum still turn and dryer run but not produce heat? I thought I had read that the dryer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
No heat
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Oct 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Robert Rankin
