Question about Nikon D50 Digital Camera with 18-55mm Lens
Continous shooting mode
My camera is right out of the box. In full auto mode, the camera rarely shoots more than one picture in continuous mode. It has done it only twice despite many attempts. I followed the manual to change the setting to continuous. Is there something I have missed. I read the manual cover to cover. thanks
    Genius:
  • 2,985 Answers
The the Complete manual that is a PDF file on the CD. If satisfied you are doing everything you should contact customer support with regard a return for replacement.
Posted on Aug 03, 2007
SOURCE:
How do I set the continous shooting on my finepix s3380?
This information will be on page 40-41 of your user manual. If you do not have it, send me an email to LBrown18062@hotmail.com.
1. Choose a continuous shooting mode. Press the progressing camera button to display continuous shooting options. Press selector < or > to highlight the desired option and press MENU/OK.
2. Press the shutter button halfway to focus.
3. Pictures will be taken while the shutter button is pressed. Shooting ends when the shutter button is released, memory is full, or the selected number of shots has been taken.
Jan 23, 2012 | Fuji Cameras
How do i use the burst mode on my nikon coolpix s6000?
For Nikon s6000 (altho this question is posted in D5000 section)
Hope you have read the instruction manual by now. In Auto mode, go through the menu to get the shooting mode - there are I think 2 different continous shooting modes for your camera - one standard and one sport (2 others but they either select the best shot of serveral or combine them to make the best shot). Pretty impressive. Don't look in the manual for 'burst' mode, it's called 'continuous'.
For D5000, menu and again shooting options.
Feb 24, 2011 | Nikon D5000 Digital Camera
I am looking to learn how to set the camera to take a sequence of delayed shots..how do I do this..?
The camera shoots continuously while the shutter button is held down.
there are three options for it
Continuous(Approx. 4.0 img/sec)
Shooting AF (Approx. 1.1 img per secnd)
Shooting LV (1.2 images per secnd)
(Live View)
Press teh shutter button.
Use up and down buttons to select the shooting modes.
The camera will continue to reord continous images as long as the shutter button is held down.
The taking will cease when it is released.
Feb 05, 2011 | Canon PowerShot SX1 IS Digital Camera
Contunues shooting
You put the camera into one of the Continuous modes by holding the Release Mode button (to the right of the LCD control panel on the top of the camera, marked with a set of overlapping rectangles) and turning the command dial on the back. The two choices are Continuous Low and Continous High (marked with the overlapping rectangles and the letter "L" or "H"). Frame and shoot as normal.
In continous mode the camera will take pictures as long as your finger remains on the shutter release button or until the buffer fills up. In Continous High the camera will take as many as 4.5 pictures a second. Custom Setting #d6 controls how fast Continous Low shoots.
Bear in mind that the speeds mentioned are only maximums. If your shutter speed is set to half a second, you're obviously not going to take four pictures in one second.
This is all in the manual, under "Release Mode".
Jun 11, 2010 | Nikon D90 Digital Camera with 18-105mm...
Moultrie D 4.0 continous exposures
..your not in "Interval Mode", are you?? IF your cam is set to start an "interval @ say 2400hrs( midnight) and to take pics every 1 min./5 min/;ect., IT WILL!
Make sure you're in "AUTO MODE"...It's easy to accidently hit the mode switch when moving the power switch from off to on..(I didn't find this out by reading a book...)
Feb 22, 2009 | Moultrie MFH-DGS-100 Digital Camera
Continuous mode
i think the frame rate is 1.3 frames per second.
Issue:
How do I set Continuous Shooting?
Solution: Setting Continuous Shooting mode PowerShot SD750 and SD1000.
Continuous Shooting In this mode, the camera shoots continuously while the shutter button is held down. Recording ceases when the shutter button is released. In addition, under the following conditions, continuous shooting can occur at a consistent interval until the SD card is full*.
  • A resolution and compression combination other than 145.gif and 129.gif is selected.
    * If continuous shooting suddenly stops, the SD card may be full.
Continuous shooting is available in all modes except 171.gif[AUTO], stitch_assist_icon.gif[Stitch Assist], coloraccentdropper.gif[Color Accent] and colorswapdropper.gif[Color Swap].
To set Continuous Shooting
  1. Press the cont_icon.gifbutton to display cont_icon.gif.
  2. Shoot the image.
    The camera will continue to record successive images while the shutter button is fully pressed. Recording will cease when the shutter button is released, the card is full or the card does not support a write speed to allow continuous shooting to continue.
To Cancel Continuous Shooting
  1. Press the cont_icon.gif button twice to display single_icon.gif.
caution_a70.gifTo enhance the continuous shooting performance when you suspect the speed has dropped, you are recommended to format the SD card in the camera (Low Level Format) after you save all its images to your computer. note_icon_a70.gif
  • The interval between shots may lengthen slightly when the camera's built-in memory fills.
  • If the flash is firing, the interval between shots will lengthen to accommodate the flash's charging requirements.
Feb 18, 2009 | Canon PowerShot SD1000 Digital Camera
Instructions ''continuous shooting'' for canon powershot sx110 is
Continuous shooting mode is not available when in Auto, Movie, or Stitch Assist mode. You must select P, Av, Tv, M or one of the preset shooting modes to be able to select continuous shooting. If you didn't get a manual with your camera, you can view / download one here.
Nov 25, 2008 | Canon PowerShot A75 Digital Camera
Just purchased a canon A590. on page 84 of user guide, continuous shooting is described. I'm somewhat familiar with SD cards, but Canon implies that I have to use their MSH type SD card to use the...
I don't own an A590 but I've been handling cameras since the Kodak Instamatic days, so I'll try to help you. I checked out the Canon website for the A590. and they don't specifically state the MSH type SD card. The camera can do 1.4 fps or frames per second of continous shooting. But it also identifies a 20 and 30fps which refers to the movie mode. If the manual states a MSH type Sd card, it usually means that the card may be of a faster recording speed to take continous shots. But I think what you might mean continous shots could be the 3 or 5 second burst on the Digital SLR cameras. These modes are usually for sports and very good for Formular 1 racing pictures. The specs of your camera does not have a sports mode or any continous burst. So you will be stuck in the 1.4fps levels. Let me know if this helps.
Nov 12, 2008 | Canon Cameras
Accessing Continuous Mode
Some details first...
  • The continous icon looks like multiple papers stacked on top of each other (in contrast the normal icon for single shot is a square box with an S in it so you can get it back to normal)
  • The camera takes shots at 1.5 frames per second, or about three frames every two seconds for image size of 2272x1704.
  • The shutter-release button has to be held down
  • Continuous is not available in HI image quality
  • Shooting will slow when memory buffer fills.
Setting to continuous...
  • Put your camera in P, S, A, or M mode.
    • I suggest P mode, this is for Program mode and does everything as Auto does, but allows you to override settings (except Aperture and Shutter).
  • Press the Menu button
  • Access the Continuous menu
  • Select the Continuous menu option, again looks like layered papers.
Please rate as FixYa! ThankYa!
Nov 04, 2007 | Nikon Coolpix 4500 Digital Camera
“Shoot and Select” Modes
e “shoot and select” modes allows you to select an image out of a sequence of still pictures you have taken by depressing the shutter button and storing it. This is best for shooting moving objects. SHOOT & SELECT 1: Shoots a rapid succession of 4 still pictures by keeping the shutter button pressed. SHOOT & SELECT 2: Shoots a succession of still pictures by keeping the shutter button pressed. The Stylus 500 will continue to shoot until you take your finger off the shutter button or until the card is full. After shooting, you will have the option to immediately delete the pictures you do not wish to keep.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
37 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
