Question about Dell 922 All-In-One InkJet Printer
Printer Hi I have a dell 926 all in 1 printer which I have not been able to use since the language is accidentally set in Russian, there is nothing in the owners manaul or at Dell's web site to help fix this and put it back to English.. Can anyone help. Thanks
  • 628 Answers
Try this solution: press Power and Cancel buttons and hold them both for about 10-15 seconds - - then "Language Options" scrolls across the screen and one can select using the Menu button. We're now able to read messages in English!
Posted on Dec 01, 2008
Why does the printer stop before completing all pages?
Check It printer page setting and page size...etc.
Read More Help.. Dell Printer Support
Thanks,
Aug 08, 2014 | Dell 926 Photo-926 All-In-One Printer 926...
My Dell Photo 926 stopped printing in color. It prints in black and white. If I make a copy, it can still make a color copy. I'm stuck.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
Jul 19, 2009 | Dell 926 All-In-One InkJet Printer
Re install Dell 926 printer
Go to this site and on the left hand side of the screen select "Download and install the 926 printer drivers". Just follow the instructions as given and select the correct OS.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=295FA22157850234E040A68F5B281614&doclang=en&cs=
May 13, 2009 | Dell 926 All-In-One InkJet Printer
A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the network while others are locally connected to a computer. I have worked with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold down the button to turn off then turn back on. You can also unplug it from its power source then plug back in.
Power cycling this printer should reset the language to default (English) or it will let you select the language when it comes back on. If that doesn't work then you can try to change it using the installed software.
Considering the fact that someone accidentally changed the language, I am assuming this printer is connected directly to a computer that you all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB or parrallel port) then you should have an HP Toolbox app or some other program that allows you to configure software related settings for the device. Open this tool and you should find an option for the language. This may not be available, depending on how the installation was handled (if it was installed using the CD provided by the manufacturer or installed using downloaded drivers).
Try this out and let me know if it helps.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Ever sence I have received my Model926 Printer service tag # 692tsd1 serv.code 13609638613 I have had trouble with the display not giving me the English language. I talked to the service department by...
Kindly try the following steps to solve your problem , with the language setting on the printer. If the same did not fix the issue , get the printer replaced from Dell, because if the solution below did fix your issue there nothing much that can be done.
Restore the Dell™All-In-One 926 printer to factory default settings.
To restore the Dell™All-In-One 926 printer to factory default settings, follow these steps:
new_note.jpg Note: Restoring the printer to factory default settings will erase any data added into printer memory, such as fax phone numbers.
  1. Turn off the printer power.
  2. Disconnect the printer power brick and wait for 10 seconds.
  3. While holding down the Start and Cancel buttons, re-insert the printer power brick.
  4. Hold the Start and Cancel buttons until the power LED begins blinking and the printer shuts itself off.
  5. Turn on the printer power
Thanks
proton
Jul 25, 2008 | Office Equipment & Supplies
Printer Dell Photo All-in-One Printer 926 language
Here's an effective way to change the language on the 926 printer *turn on the printer *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key four (4) times *press the check button *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key until you find "English" *press the check button let me know if it works thanks!
May 25, 2008 | Dell Photo 964 All-In-One InkJet Printer
Language setting
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
Jun 12, 2007 | HP LaserJet 3055 All-In-One Printer
Dell 922 All-In-One InkJet Printer Logo
43 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
