Question about Jenn-Air Jenn Air 22 Cu. Ft. Side by Side Counter depth Refrigerator, JCD2290HE
TRYING TO REMOVE THE COVER ON THE FREEZER DOOR THAT COVERS THE WA
CANT GET THE COVER OFF
  • 33 Answers
Most of these covers are made of plastic with snap together tabs. Sometimes there is a "popout" plastic piece with a screw/s behind it.
Posted on Nov 29, 2008
Beko instructions
You will have to remove the hinge cover at the top. Usually just snaps down on top of hing or could have a few screws.Then remove the screws securing the hinge. Make sure you make a diagram or take a few images of how its put together (they can be a pain if you forget how). Before you do that look at the top center, and lower sides of the side you want to put the doors on, not all units are made to be reversible. If yours is there should be plastic snap in covers covering the screw holes. Remove the covers, move the door and gaskets, etc over, align properly and put plastic covers in holes on side you removed doors from.
Aug 20, 2014 | Beko CF7914APS Silver 348 l Fridge Freezer...
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Freezer not cold, everything is thawed and temperature in freezer at ~35 f.
hi,
probably an ice dam. unplug it and put everything in another fridge.
take all the shelves and icemaker parts out of the freezer and in the back usually is an access cover that runs the length of the freezer depending on the model, try and and take that off. put a hairdryer in the door and check it every 10 minutes. if you cant get the cover off put the dryer in the freezer on LOW ONLY and bring the door shut so theres a few inches for air circulation. and check it every10-15 minutes, keep the hair dryer away from plastic parts, so its shooting straight towards the back. it may take a day without removing the cover but that might get you going. dont use sharp objects to remove that ice blockage, let if fall away. if its still acting up after a couple days of this call the repairman.
jm
Nov 09, 2010 | KitchenAid Superba KSRS27CN Side by Side...
My GE model GSS25JFMDWW Ice despenser door does not close properly, allowing warm, moist air to enter the freezer and ice/frost build up. What would be the exact repair procedure for this problem?
First , remove the top freezer door hinge cover , and disconnect the plug there . This removes power to the door . 1 ) Use a small screwdriver on the bottom of the dispensor board , and twist to unsnap the bottom of the board . 2 ) Remove the 3 plugs from the board . 3 ) remove the 4 screws , holding the dispensor cover on , and slide cover out . 4 ) At the top right , you will see a black solenoid with a plunger ( usually rust ) . This is the part that needs replaced . Pt # WR62X10055 . This part comes with the plunger . Do not try to just clean , as this problem will happen again if not replaced . Re-assemble in reverse .
Sep 27, 2009 | GE Refrigerators
Ice chute door hangs open ...kenmore 106.57904700
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
REMOVE FRONT WATER AND ICE COVER
Remove the top freezer door hinge cover and disconnect the plug . This removes power to the door . Using a butter knife or small screwdriver , insert it between the grill and the lower portion inside of the dispensor cover . Press down and inward slightly , to push the cover outward . On both sides of the grill . Plastic clips , so be careful . Disconnect the plug onto the cover and lift cover upward , to clear the upper tabs .
Sep 06, 2009 | Kenmore Refrigerators
The ice door does not close so ice has formed inside the freezer, how do I get the fromt cover off to check the plunger to see if it is working to close the little door.
Remove the top freezer hinge cover and disconnect the plug there . This removes power to the door . Between the grill and the lower portion of the dispensor cover , at the inside bottom , use a butter knife and push down and inward , to force the lower portion of the cover out slightly . Do this on both sides , being careful due to plastic tabs can break , Once bottom is out , lift the dispensor cover upward to disenguage top plastic tabs . Unplug the cover from the plugin . Remove the 2 screws holding the dispensor housing and slide outward . This gives you access to the door flap , flap spring and pin . You will be able to see the problem .
Sep 06, 2009 | Whirlpool Refrigerators
I have 1998 buick regal i cant find paint code
look under the spare tire cover, should be on under side of cover, options are in alph. order. S.R. Peace
Mar 19, 2009 | 1998 Buick Regal
Indesit w93
Below the door, there's a plastic cover several inches tall, full machine width. Just remove it and on the right you'll see the filter. Make sure machine is unplugged. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Apr 16, 2008 | Indesit WA 125 Front Load Washer
Jenn-Air Jenn Air 22 Cu. Ft. Side by Side Counter depth Refrigerator, JCD2290HE Logo
101 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
