I have a 2006 poulan PB1638LT.It cranks but wwill not start. If I spray a small amount of carb cleaner in the intake it starts and runs OK. otherwise it will not fire. It has 140 compression. Replaced plug. Cleaned carb. What am I missing. There is an adjustment on carb but has the plastic lock. I just purchased this mower.Thanks fr any help you can offer
Is there power going to the solenoid on the bottom of the carb? is the solenoid stuck from old fuel sitting in the carb?if there is no power to the solenoid check the safety switches
Testimonial: "Mike I removed the solenoid and replaced it with a bolt. Starts every time. I am only getting about 8 volts to the solenoid. It does not pull down just vibrates. I tried it out of the carb. I cut grass with the bolt in. Is that bad or do I really need that soleniid"
the solenoid is a anti back fire valve and is a safety item safety items should only be removed to test if you only have 8 volts to it you have a voltage drop in the circuit this can be from a loose or coroted connection the voltage can also drop in a safety switch on the clutch/brake as i said safety items should only be used to test something
SOURCE: mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
SOURCE: mower wont stay running
Hello nater357:
>>From your Description it Sounds like a Bad Carburetor Solenoid, Restricted Carburetor Passages or a Stuck Carburetor Float Needle Valve.
>>The Following is a Basic Instruction File I made for Checking the Carburetor Solenoid. Any Input is Appreciated.
>>**Check for Current/Voltage (10.5 VDC Minimum) to the Carburetor Shut Off Solenoid. If the Carburetor Shut Off Solenoid has Current, then On Some Solenoids you can Remove the Needle and Replace the Solenoid to Test them.
>>****PLEASE DO NOT OPERATE THE MOWER WITH THE SOLENOID BYPASSED IN THIS MANNER. THIS IS "ONLY" FOR TESTING.****
>>For Others, Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 1/2" to 3/4" Long for the Horizontal Mount Solenoids and 1/4" to 1/2" Long for the Vertical Mount Solenoids. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid.
>>***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES***
>>Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jet Properly.** **Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. There is Some Slop/Free Play in the Solenoid Pin. Usually the Electromagnet is Simply Not Pulling the Pin as it Should or there is a Small Bur on the Pin. Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. Clean and Lightly Oil the Pin before Inserting it Back into the Solenoid. Just a Film of Oil is All it Takes.**
>>If the Carburetor Solenoid is Good, then
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
SOURCE: Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Thanks Mike. I have power to solenoid. changed fuel filter.and it is spinning fast. does not want to fire til I spray carb cleaner in the intake. after it runs 5 min it will restart immediately.even after it sits 15 min. I am lst as what to try next. I ust put some start your engines in the fuel I will try later today .
Just for info took the plug off the ign switch, cleaned and replaced and now have solenoid back in and it works. Problem solved. Thanks Mike
